[snappyHexMesh] Why does SnappyHexMesh snap out pieces of my stl file? |
April 8, 2017, 10:01 |
Jordan Tracey
I am creating a shell and tube heat exchanger. I imported stl files from freeCAD and call them through snappyHexMesh. There are 14 parts as follows: 1 & 2 = plates between shell and tube sides 3 - 9 = tubes 10 - 13 = baffles 14 = outside shell including inlets / outlets When I run "snappyHexMesh -overwrite" and "paraFoam" the geometry is all there however the middle of part 14 (the part the surrounds the tubes/baffles is snapped out. This is strange because Part 14 that surrounds the ends of the exchanger is still there. So I changed the geometry a bit: 1) I removed parts 1,2 and 14. 2) I created 5 new cylinders: - 2 for the ends of the exchanger - 2 for parts 1 and 2 (to separate the shell from the tube side - and 1 for around the tubes/baffles (the part that was snapped out before) However I am still getting the same issue of the middle cylinder being snapped out. Is there a particular command that I can use to ensure that the snappy keeps all the parts contained within the middle shell? P.s. I set my location in mesh inside the middle shell. Any help would be greatly appreciated. |
April 21, 2017, 06:06 |
Kal-El
Rep Power: 9 |
Is the part (#14) completely inside your blockMesh?
Can you send pictures? I have a hard time understanding your problem. |
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X | gschaider | OpenFOAM Installation | 136 | October 10, 2017 17:25 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
