[snappyHexMesh] searchableRotatedBox feature in sHM
Old   June 12, 2017, 08:50
Post searchableRotatedBox feature in sHM
Marcell Szabo-Meszaros
Samwise is on a distinguished road
Dear Foamers,
I'd like to add the searchableRotatedBox feature to the meshtools:
http://www.openfoam.com/documentatio...otatedbox.html
I've added the .C and .H sourcecodes to the src/meshtools/searchableSurface but when I'd like to use this option to the sHMdict it does not recognize as a function. Any ideas, may I missed something?
Thank you for your answer, in advance,
Sincerely,
Samwise
Samwise is offline   Reply With Quote
searchablerotatedbox, snap, snappy hex mesh
[snappyHexMesh] Failed Edge Snap with box geometry and correct feature capture thiagomarinho OpenFOAM Meshing & Mesh Conversion 7 May 7, 2022 09:19
[snappyHexMesh] SHM: sharp edge resolving problem with explicit feature edges piotr.mecht OpenFOAM Meshing & Mesh Conversion 21 May 9, 2020 14:56
[snappyHexMesh] SHM not snapping to some surfaces Swift OpenFOAM Meshing & Mesh Conversion 13 January 4, 2016 01:56
[snappyHexMesh] Manually define feature edges in SHM palgroth OpenFOAM Meshing & Mesh Conversion 0 July 9, 2014 04:22
[snappyHexMesh] SHM: feature edge snapping not conforming thab OpenFOAM Meshing & Mesh Conversion 3 November 26, 2012 14:04
