[blockMesh] Merging multiple blocks of diferent mesh density.
Like Tree1Likes
  • 1 Post By Antimony
Old   July 7, 2017, 20:27
Default Merging multiple blocks of diferent mesh density.
Tom
Algebraist is on a distinguished road
Hello all,
I'm trying to set up the following geometry in with blockMesh:
Where the light blue area represents a coarse mesh, and the darker blue a fine mesh.
The simplest way to do it would be to simply use face matching to ensure the rough sections is all connected, but then using mergePatchPairs to connect the three inner faces of the fine section won't work because of adjacency.
Merging the top and bottom boxes into the center box and then using merging the left rough box into that combined box doesn't work either because it creates faces with less then 3 points.
Can anyone suggest a work around?
I've also heard people suggesting connecting such a geometry with cyclical boundaries - but doesn't that only work with meshes of the same density?
Algebraist is offline   Reply With Quote
Old   July 15, 2017, 14:04
Tom
CyclicAMI seems to actually be my best bet, but I'm not sure how to use it. Below is my best guess based on checking several threads here on CFD Online and the OpenFOAM user guide.
|  \\    /   O peration     | Version:  4.1                                   |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 0.1;
vertices
//left rough 'c' box
    //back plane
        (0 0 0)//0
        (180 0 0)//1
        (260 0 0)//2
        (260 90 0)//3
        (180 90 0)//4
        (180 170 0)//5
        (260 170 0)//6
        (260 260 0)//7
        (180 260 0)//8
        (0 260 0)//9
    //front plane
        (0 0 20)//10
        (180 0 20)//11
        (260 0 20)//12
        (260 90 20)//13
        (180 90 20)//14
        (180 170 20)//15
        (260 170 20)//16
        (260 260 20)//17
        (180 260 20)//18
        (0 260 20)//19
//left center box
    //back plane
        (180 90 0)//20
        (260 90 0)//21
        (260 170 0)//22
        (180 170 0)//23
    //front plane
        (180 90 20)//24
        (260 90 20)//25
        (260 170 20)//26
        (180 170 20)//27
blocks
    hex (0 1 8 9 10 11 18 19) (18 26 20) simpleGrading (1 1 1)//left rough box
    hex (1 2 3 4 11 12 13 14) (8 9 20) simpleGrading (1 1 1)//left bottom box
    hex (20 21 22 23 24 25 26 27) (16 160 20) simpleGrading (1 1 1)//left center box, note doubled mesh density
    hex (5 6 7 8 15 16 17 18) (8 9 20) simpleGrading (1 1 1)//left top box
edges
boundary
    inlet
        type patch;
        faces
            (10 11 18 19)//left rough box
            (11 12 13 14)//left bottom box
            (24 25 26 27)//left center box
            (15 16 17 18)//left top box
    outlet
        type patch;
        faces
            (0 1 8 9)//left rough box
            (1 2 3 4)//left bottom box
            (20 21 22 23)//left center box
            (5 6 7 8)//left top box
    fixedWalls
        type wall;
        faces
            //left rough box
        (0 1 11 10)//bottom
        (0 10 19 9)//left wall
        (8 9 19 18)//top
            //left bottom box
        (1 2 12 11)//bottom
        (2 3 13 12)//right
            //left center box
        (21 22 26 25)//right
            //left top box
        (8 18 17 7)//top
        (6 7 17 16)//right
//use the Arbitray Mesh Interface next
    inTopInterface
        type cyclicAMI;
    neighborPatch outTopInterface;
        faces
            (22 23 27 26)//
    outTopInterface//
        type cyclicAMI;
    neighborPatch inTopInterface;
        faces
            (5 6 16 15)//
    outBottomInterface
        type cyclicAMI;
    neighborPatch inBottomInterface;
        faces
            (3 4 14 13)//
    inBottomInterface
        type cyclicAMI;
    neighborPatch outBottomInterface;
        faces
            (20 21 25 24)//
    leftRightInterface
        type cyclicAMI;
    neighborPatch rightLeftInterface;
        faces
            (1 8 18 11)//
    rightLeftInterface
        type cyclicAMI;
    neighborPatch leftRightInterface;
        faces
            (20 24 27 23)//
Unfortunately, it's giving me the following error:
--> FOAM FATAL IO ERROR:
No "neighbourPatch" or "coupleGroup" provided.
I'm at a loss as to how to proceed.
Old   July 18, 2017, 22:28
Antimony is on a distinguished road
Seems to me that it is a simple issue with your spelling.
neighbourPatch uses the British spelling, while you have used the American spelling.
Cheers,
Antimony
Algebraist likes this.
Antimony is offline   Reply With Quote
Old   July 19, 2017, 09:29
Tom
Originally Posted by Antimony View Post
Cheers,
Antimony
It's always the little things that get you.
Thanks Antimony.
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 04:17
[Other] Multiple blocks for moving mesh jiahui_93 OpenFOAM Meshing & Mesh Conversion 0 March 4, 2018 02:24
[ICEM] meshing-incomplete mesh in part after moving blocks to separate domains Mfaizan ANSYS Meshing & Geometry 8 November 29, 2015 21:11
