[Commercial meshers] Problem in import mesh with two coupled region from gambit
Old   December 31, 2015, 11:17
Question Problem in import mesh with two coupled region from gambit
Hesam
rapierrz is on a distinguished road
Hi friends,
I import gambit mesh file with two coupled regions,solid and fluid,then
I write this codes:
fluentMeshToFoam meshName.msh -writeSets
setsToZones -noFlipMap
splitMeshRegions -cellZones -overwrite
but error is:
Adding patches
Inserting patch fluid_to_solid to slot 6 out of 6
--> FOAM Warning :
From function gAverage(const UList<Type>&)
in file /opt/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/FieldFunctions.C at line 524
empty field, returning zero.
--> FOAM FATAL ERROR:
request for polyMesh solid from objectRegistry sphereQuench failed
available objects of type polyMesh are
1
region0
From function objectRegistry::lookupObject<Type>(const word&) const
in file /opt/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 140.
FOAM aborting
Aborted (core dumped)
How i can solve this problem ???
rapierrz is offline   Reply With Quote
Old   February 3, 2016, 08:06
Smile
Hesam
I solve this problem with openfoam 2.1.1 and 2.2.1.
I write this codes in openfoam 2.2.1 and 2.1.1 and then use it on OF1.6ext.
Old   October 30, 2017, 12:20
ahmadreza
ahmad052 is on a distinguished road
Can you describe more?
ahmad052 is offline   Reply With Quote
[Other] conformed FSI mesh for unstructured fluid region ashish.svm OpenFOAM Meshing & Mesh Conversion 10 August 2, 2019 08:40
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
problem when I import mesh with cyclic graduated BC Cyp OpenFOAM 0 March 3, 2011 10:38
