[snappyHexMesh] searchableBox at an angle?
Old   July 21, 2011, 10:27
Default searchableBox at an angle?
Alex
bigbang is on a distinguished road
Is it possible to define a type searchableBox with an angle?
I want to specify a region for a rectangular area that is not parallel to the yz plane.
Thank you
bigbang is offline   Reply With Quote
Old   October 17, 2017, 03:05
Default Bump
Fridrik Magnusson
Fridrik is on a distinguished road
Did you find a solution back in 2011, Want the same thing.
- Fridrik Magnusson
Fridrik is offline   Reply With Quote
Old   November 1, 2017, 22:47
slan
aaron_lan is on a distinguished road
Send a message via MSN to aaron_lan
- Fridrik Magnusson
Any progress on this function?
aaron_lan is offline   Reply With Quote
Old   November 2, 2017, 01:59
Fridrik Magnusson
Nope :/ i found a workaround, drew it in a CAD program, where it should be, then exported it as an *.stl - Then it had it shape and rotation.
- Fridrik Magnusson
Old   November 2, 2017, 02:39
slan
- Fridrik Magnusson
Thanks for the workaround.
I saw your another post about editing snappyHexMeshDict with coordinateRotation. I am trying to figure out a solution in this direction. Any suggestion from your experience?
Dynamic contact angle calculation in multiphaseInterFoam rajeshchem OpenFOAM 3 December 23, 2022 14:00
Dynamic contact angle issue: fluent UDF couldn't set the correct contact angle FelixJJ FLUENT 2 October 20, 2021 02:39
[snappyHexMesh] snappyhexmesh refine volume with angle using something similar to searchableBox jptorol OpenFOAM Meshing & Mesh Conversion 0 May 13, 2015 16:57
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
Normal vector, slope and aspect angle g_niro Main CFD Forum 0 February 2, 2011 17:24
