[blockMesh] How to define a cellzone while using blockMesh |
November 25, 2017, 14:59 |
Deep
Rep Power: 8 |
I have a very simple geometry and I have created it using blockMesh only. So there are two blocks: first is the horizontal duct while the second is another smaller duct merging with the first bigger duct at 90deg. See attached pictures for visualisation.
Now I want to define these two blocks as separate cellzones. e.g. say one of them as porous zone. How can I do that? (The related tutorials use SHM or FHM, I want to avoid that) I also noticed that after running blockMesh, [sets] folder is created in polyMesh. Isn't that created when blockMesh can't use some the faces or points? The [sets] folder for me contains these exact two zones that I mentioned above!! I don't understand why? 1. Is there any way I can perhaps use these region0 and region1 ? 2. If not, is it a good idea to use something like Code:
splitMeshRegions -makeCellZones |
November 25, 2017, 15:16 |
Tobias Holzmann
Rep Power: 51 |
in your particular case (I am not familiar with the capabilities of blockMesh) I would use setSets and use the sets in order to create a cellZones. Its easy and should be a 3 liner - if you do not have the sets, build a cellSet and based on that, you can create a cellZone.
Keep foaming, Tobias Holzmann |
November 27, 2017, 00:26 |
Not sure how you created your blockMesh, but you can name each block as well. So instead of "region0" and "region1" you could have something like "bigBlock" and "smallBlock" As Tobi has mentioned you can use setSets to create your cellZones. Alternatively, you can use topoSet and convert these sets (region0 & region1) into cellZones using setToCellZone (Ref: https://github.com/OpenFOAM/OpenFOAM...et/topoSetDict) Hope this helps. Cheers, Antimony |
November 27, 2017, 04:48 |
Rep Power: 20 |
This is how you can create cellZones with blockMesh
hex (0 1 2 3 4 5 6 7) nameOfCellZone (1 2 3) simpleGrading (1 1 1) |
November 27, 2017, 05:13 |
Deep
Rep Power: 8 |
Whoa, alright. Thanks for your inputs guys. Let me try this out today and I'll update!
November 27, 2017, 12:46 |
#6 | |
Deep
Rep Power: 8 |
OK. Update:
I did not try what Tobi and Antimony suggested as this seemed to work. Quote:
However when I run the solver (porousSimpleFoam) am now getting "floating point exception (core dumped)" error. The log.porousSimpleFoam file has only this: Code:
Starting time loop Time = 1 GAMG: Solving for p, Initial residual = 1, Final residual = 855359.7971, No Iterations 1000 time step continuity errors : sum local = 2261772.402, global = -549976.5525, cumulative = -549976.5525 smoothSolver: Solving for epsilon, Initial residual = 0.9989955956, Final residual = 0.04815760269, No Iterations 16 smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.02483197907, No Iterations 2 ExecutionTime = 625 s ClockTime = 649 s Time = 2 2. While defining the interface boundaries (for the two ducts), I had used mergePatchPairs to project the smaller surface onto the larger surface. "Type" for both of these was wall. Is that a wrong choice? I was a bit skeptical about this since considering my geometry only part of the bigger duct bottom is the real wall while the interface should allow flow. I have attached my fvSolution and fvScheme files here for reference. fvSchemes Code:
FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss upwind; div((nuEff*dev(T(grad(U))))) Gauss linear; div(phi,epsilon) bounded Gauss upwind; div(phi,k) bounded Gauss upwind; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p ; } Code:
FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; tolerance 1e-08; relTol 0.05; smoother GaussSeidel; cacheAgglomeration on; nCellsInCoarsestLevel 20; agglomerator faceAreaPair; mergeLevels 1; } "(U|k|epsilon)" { solver smoothSolver; smoother symGaussSeidel; nSweeps 2; tolerance 1e-07; relTol 0.1; } } SIMPLE { nUCorrectors 2; nNonOrthogonalCorrectors 0; } relaxationFactors { fields { p 0.3; } equations { U 0.7; k 0.9; epsilon 0.9; } } |
November 28, 2017, 09:49 |
Deep
Rep Power: 8 |
Alright. I found a work around. Although I do not know what is the reason for this.
I shifted the underrelaxation factor for U from equations to fields brackets. And this worked. Which brings up new question. I'm going to open a new thread to clarity about that. Update: and the thread is here: Difference between "fields" and "equations" relaxation sub-directories in fvSolution Thank you folks for your help. |
blockmesh, cellzones, mergepatchpairs, porous |
HELP----Surface Reaction UDF | Ashi | Fluent UDF and Scheme Programming | 1 | May 19, 2020 21:13 |
UDF: trying to implement a Kinetic Equation source term | er.mkumar | Fluent UDF and Scheme Programming | 35 | March 22, 2019 10:20 |
[Salome] SALOME : How to define several CellZone | utawalpa | OpenFOAM Meshing & Mesh Conversion | 0 | March 23, 2018 13:19 |
Installing OF 1.6 on Mac OS X | gschaider | OpenFOAM Installation | 129 | June 19, 2010 09:23 |
[blockMesh] Is it possible to define a CONSTANT in the blockMesh file? | om3ro | OpenFOAM Meshing & Mesh Conversion | 2 | March 19, 2010 02:14 |
