[snappyHexMesh] how to define node's on edge in SHM? |
February 18, 2018, 04:40 |
arash
Rep Power: 8 |
hi
I wanted to know is there a way, like the Gambit, that set up SnappyHexMesh to set a certain number of nodes an edge of the geometry? That is to divide the edge into segments with a certain distance? I know that there is no direct way. so I tried to set parameters like features/levels, refinementSurfaces/levels, refinementRegions. but Due to several parameters on this mesh affected this section and I could not find the right solution for dividing one side into the number of different parts. and sorry for my very bad language thanks. |
[snappyHexMesh] SHM: sharp edge resolving problem with explicit feature edges | piotr.mecht | OpenFOAM Meshing & Mesh Conversion | 21 | May 9, 2020 14:56 |
[snappyHexMesh] how to define node's on edge in snappyhexmesh? | handicraft | OpenFOAM Meshing & Mesh Conversion | 1 | October 19, 2018 19:39 |
[ICEM] Shifted Periodic topology | venkat_aero2007 | ANSYS Meshing & Geometry | 17 | August 27, 2013 01:41 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 11:48 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
