[blockMesh] Mesh refinement for a cylindrical mesh
Old   January 20, 2011, 05:54
Default Mesh refinement for a cylindrical mesh
lindstroem is on a distinguished road
Hi Foamers,
although I have read a lot oft posts concerning this topic, I couldn't really find an answer. Therefore sorry if it maybe was already answered!
I have created the attached mesh using blockMesh:
What I now want to do is to refine a certain area at the corner of the mesh.
Earlier I had a cube where I could refine a specified area easily using the cellSet command, but in this case, the structure of my mesh gets lost. Is there a similar tool to refine certain areas which are not "box-shaped"?
Thanks!
lindstroem is offline   Reply With Quote
Old   February 4, 2011, 07:42
little workaround is with cellSet and refineMesh with a local coordinate system. But I'm still interested in other suggestions about how to get around that cellSet only allows boxToCell, which is not optimal for the mentioned geometry.
Greetings
Old   February 7, 2011, 16:55
kalyan
hardykalyan is on a distinguished road
Greetings
cellSet also has cylinderTocell option which can extract the cells in the cylinder regions specified
hardykalyan is offline   Reply With Quote
Old   February 10, 2011, 08:31
Hi thanks for the hint! Coudl you help me with the syntax? I havent found any use of it so far...
Thanks!
Old   February 10, 2011, 13:16
Usage: cylinderToCell (p1X p1Y p1Z) (p2X p2Y p2Z) radius
Select all cells with cell centre within bounding cylinder
Old   July 30, 2012, 09:00
Teemo
Teemo is on a distinguished road
hi lindstroem,
I tried cylinderToCell to generate cylinder but the boundary is not smooth (https://docs.google.com/drawings/d/1...DW5AXeEmY/edit)since I used blockMesh to set the domain, do you have any idea about how to set the region instead of blockMesh?
Regards,
T
Teemo is offline   Reply With Quote
Old   July 30, 2012, 09:06
Hi Teemo,
you want to "generate a cylinder"? some options are snappyHexMesh or O-Grids for cylinders (can be done with blockMesh). But I do not undersant your actual problem..
Greetings
L
Old   July 30, 2012, 09:19
Teemo
Hi Lindstroem,
Sry for the bad description, I would like to test the wave load on the simplified floating cylinder-shape structure in a water tank, so I used one block to generate the whole tank and then employed toposet with cylinderToCell source to model the vertical floating object, while in paraview, you will see that the boundary of the cylinder is not smooth as as the mesh is made of only cuboidal cells(https://docs.google.com/drawings/d/1...DW5AXeEmY/edit).
Thanks,
T
Old   July 30, 2012, 09:34
Teemo
Hi again,
Could you link me any tutorial of using snappyHexMesh or O-grids for cylinders?
Many Thanks!
Old   July 30, 2012, 10:08
I'm still not sure if I get you right, but the tutorial for snappy can be found by searching for snappyHexMeshDict in your tutorial folder (e.g. grep -r snappy .) and in the User Guide and for O-Grid see the forum:
http://www.cfd-online.com/Forums/ope...disc-like.html
But if you select your cells after creation I don't know how you could get rid of the staggered bubble.. if it is just the phase fraction, it will be "smooth" after the first iteration.
Greetings
Old   July 30, 2012, 12:03
Teemo
Hi Lindstroem,
Sry for my bad English, it is not my first language.
The video linked below is what I would like to simulate.
http://www.youtube.com/watch?v=AuNWovYR6WA
My problem is :In my case, Firstly the wave tank are meshed by BlockMesh (just one block). Then I model the cylinder by using cylinderToCell but the cylinder boundary are not smooth since all cells created by blockMesh are cube.(https://docs.google.com/drawings/d/1...e6NzNv1hk/edit)
Old   July 31, 2012, 04:24
Yes, I would recommend snappyHexMesh (sHM) for that: So you use your inital block you created and within your sHMDict you define the cylinder you want to cut.. Then let sHM do the work for you and simulate your waves.
Greetings
L
Old   June 19, 2018, 05:06
Ben 017
Ben UWIHANGANYE is on a distinguished road
Originally Posted by Teemo View Post
hi lindstroem,
Regards,
T
Hello Teemo,
Have you been able to solve this?
May you help?
Indeed, I want to do the same as you wanted to do. But for my case the cylinder will be not floating but immersed in wave.
May you help with your setup.
Thank you!
Ben UWIHANGANYE is offline   Reply With Quote
Old   June 19, 2018, 05:48
Yage
Yage is on a distinguished road
Originally Posted by Ben UWIHANGANYE View Post
Hello Teemo,
May you help?
Thank you!
Hi Ben,
1. You could build up your cylinder model first (with CAD software, like SolidWorks, with STL file output), and use snappyhexMesh to input your cylinder and refine its surface.
2. You could try waves2foam package to generate waves.
Regards,
Yage
Yage is offline   Reply With Quote
Old   June 19, 2018, 06:14
Ben 017
Originally Posted by Yage View Post
Hi Ben,
Regards,
Yage
Thank you,
But i am not yet there,
I want first to map a cylinder in my fluid domain that i generated using blockMesh. I guess toposetDict can help.
I want to simulate first using pisoFoam or any simple solver.
Just help to use cylinderTocell in toposetDict to get that cylinder?
(below is my blockMesh)
How do you understand my approach?
The coordinate of the cylinder I want: center(0 0 0), diameter:0.5
Then what will be p1 and p2?
Thank you!
convertToMeters 0.1;
vertices
(200 -50 0)
(200 50 0)
(-25 50 0)
(-25 -50 0)
(200 -50 1)
(200 50 1)
(-25 50 1)
(-25 -50 1)
blocks
hex (0 1 2 3 4 5 6 7) (100 225 1) simpleGrading (1 1 1)
edges
boundary
inlet
type patch;
faces
(2 3 7 6)
outlet
type patch;
faces
(0 1 5 4)
topAndBottom
type patch;
faces
(1 2 6 5)
(0 3 7 4)
frontAndBack
type empty;
faces
(0 1 2 3)
(4 5 6 7)
mergePatchPairs
Old   June 19, 2018, 06:56
Yage
Thank you,
Thank you!
vertices
(200 -50 0)
(200 50 0)
(-25 50 0)
(-25 -50 0)
(200 -50 1)
(200 50 1)
(-25 50 1)
(-25 -50 1)
blocks
edges
boundary
inlet
type patch;
faces
(2 3 7 6)
outlet
type patch;
faces
(0 1 5 4)
topAndBottom
type patch;
faces
(1 2 6 5)
(0 3 7 4)
frontAndBack
type empty;
faces
(0 1 2 3)
(4 5 6 7)
mergePatchPairs
Hi Ben,
The setup of cylindertocell should be like
(P1X P1Y P1Z) (P2X P2Y P2Z) radius
the Px, Py... are the centres of upper and lower surface. They could be higher and lower than your "front" And "Back" since your background mesh is in 2D.
While in my experience, the cylindertoCell was not quite good to build the curved boundary of the cylinder
Yage
Old   June 19, 2018, 08:24
Ben 017
Hi Ben,
Yage
Hi Yage,
I am sorry to be disturbing again.
I humbly request if you have time , you may look on the attached folder and help me to why that cylinder in not appearing. you may help to know what i am missing in my topsetDict.
Thank you!
Old   June 19, 2018, 13:07
Yage
Hi Yage,
Thank you!
Hi
I cant check your file right now but it may be caused by the "convertToMeters". Try to rewrite your blockMesh with "convertToMeters 1".
Yage
Old   June 20, 2018, 08:34
Default cylinderTocell
  #19
Ben 017
Dear Yage,
I have refined the cell size:
convertToMeters 1;
vertices
(200 -50 0)
(200 50 0)
(-25 50 0)
(-25 -50 0)
(200 -50 1)
(200 50 1)
(-25 50 1)
(-25 -50 1)
blocks
hex (0 1 2 3 4 5 6 7) (1100 400 1) simpleGrading (1 1 1)
edges
my topoSetDict: is as follow:
FoamFile
version 2.0;
format ascii;
class dictionary;
object topoSetDict;
actions
name solid;
type cellSet;
action new;
source cylinderToCell;
sourceInfo
radius 0.5;
p1 (0 0 0); // start point on cylinder axis
p2 (0 0 1); // end point on cylinder axis
but still i am not seeing the cylinder i want in paraview.
What could be the reason?
you may check on the attached folder
Old   June 20, 2018, 10:35
Yage
Dear Yage,
convertToMeters 1;
vertices
(200 -50 0)
(200 50 0)
(-25 50 0)
(-25 -50 0)
(200 -50 1)
(200 50 1)
(-25 50 1)
(-25 -50 1)
blocks
edges
FoamFile
version 2.0;
format ascii;
class dictionary;
object topoSetDict;
actions
name solid;
type cellSet;
action new;
sourceInfo
radius 0.5;
but still, i am not seeing the cylinder i want in paraview.
Your cell is still too big, why use such a big background 225x100x1 when your cylinder is only 0.5?
1. Use small background
2. And you miss patch setup for your cylinder in blockMeshDict, adding these:
solid
type wall;
faces ();
3. In your toposetDict, add:
name solid;
type cellSet;
action invert;
4. In your allrun, add:
runApplication subsetMesh -overwrite solid -patch solid
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[snappyHexMesh] problems generating clean mesh Christian_tt OpenFOAM Meshing & Mesh Conversion 2 June 20, 2019 05:39
[snappyHexMesh] Removing further cells after SHM zonda OpenFOAM Meshing & Mesh Conversion 14 September 15, 2017 07:50
[snappyHexMesh] snappyHexMesh & Mesh around a missile sasanghomi OpenFOAM Meshing & Mesh Conversion 2 October 15, 2014 19:54
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
