March 15, 2018, 11:24 |
Acces to points and faces
Hans Kurst
Rep Power: 8 |
I have a question regarding the acces to the "points" and "faces" file. These files were created by blockMesh. If I open them there's only a list of hieroglyphs. Can somebody tell me how to obtain the data? The core problem is to find out the order of the faces of one patch. I would be infinitely grateful for your help!!! |
March 16, 2018, 05:20 |
It sounds like you need to change binary format to ascii in system/controlDict and than run: Code:
foamFormatConvert But it may also be interesting to load the data in paraview and use the generate Ids filter. Best Regards, Tom |
[snappyHexMesh] Help with Snappy: no layers growing | GianF | OpenFOAM Meshing & Mesh Conversion | 2 | September 23, 2020 08:26 |
[snappyHexMesh] Layers not growing at all | zonda | OpenFOAM Meshing & Mesh Conversion | 12 | June 6, 2020 11:28 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
