[blockMesh] Any simple way to view blockMeshDict vertex numbers/indices? |
April 16, 2014, 15:37 |
Andrew Somorjai
Rep Power: 12 |
I know that Paraview is used for viewing a mesh once blockMesh creates one from the blockMeshDict file but seeing a grid and understand the relationship between the indices used to connect the vertices are two different things. Is there some easy way to visualize the indices without making crude drawings by hand in GIMP or some other image editor.
thanks |
April 16, 2014, 15:48 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer:
edit: There is at least one of two more possibilities, but I can't remember their names... Last edited by wyldckat; April 16, 2014 at 15:49. Reason: see "edit:" |
April 16, 2014, 16:24 |
#3 | |
Andrew Somorjai
Rep Power: 12 |
April 17, 2014, 04:39 |
hexBlocker
Roman Thiele
Rep Power: 20 |
Hej,
I know that Nicolas also develops a GUI for blockMesh, called hexBlocker http://www.cfd-online.com/Forums/ope...a-release.html This is also an active git repository https://github.com/nicolasedh
~roman |
April 19, 2014, 10:43 |
Bruno Santos
Rep Power: 128 |
Greetings to all!
@Roman: Many thanks for reminding me of HexBlocker! I've taken the time to revamp the wiki page for blockMesh: http://openfoamwiki.net/index.php/BlockMesh - if you remember any more helpful features and hints about blockMesh, feel free to add it to that wiki page! Best regards, Bruno |
July 8, 2014, 09:11 |
Gerhard Holzinger
Rep Power: 28 |
PyFoamDisplayBlockMesh can display everything defined in blockMeshDict even when meshing fails due to some errors.
http://openfoamwiki.net/index.php/Co...ayBlockMesh.py |
July 5, 2018, 07:18 |
Vania
Rep Power: 9 |
Dear all,
I am trying to visualize the vertex numbers/indices of a case. Doing paraFoam -block in the case folder I get : bash-4.1$ paraFoam -block Created temporary 'wavemakerTank_teste.blockMesh' fileName::stripInvalid() called for invalid fileName /home/user/Desktop/LinktoOpenFOAM/user-v1606+/run/tutorials/olaFlow/tutorials/wavemakerTank_teste/wavemakerTank_teste.blockMesh For debug level (= 2) > 1 this is considered fatal So there is some problem with paraFoam, I suppose. Following Phicau's suggestion, I moved the folder to /home/user/ and the instruction is now working. |
blockmeshdict, index, paraview |
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner | panpanzhong | OpenFOAM Meshing & Mesh Conversion | 5 | July 3, 2018 05:53 |
SIMPLE algorithm in 3D cylindrical coordinates | zouchu | Main CFD Forum | 1 | January 20, 2014 17:02 |
Inconsistent Grading Caused by Simple Translation | wildfire230 | OpenFOAM Running, Solving & CFD | 5 | August 25, 2013 11:08 |
[CAD formats] my stl surface is seen as just a line | rcastilla | OpenFOAM Meshing & Mesh Conversion | 2 | January 6, 2010 01:30 |
[blockMesh] this is a simple one but I have no idea what I did wrong | msha | OpenFOAM Meshing & Mesh Conversion | 2 | September 28, 2007 03:22 |
