[snappyHexMesh] Valve .stl format
Old   May 15, 2018, 02:33
Default Valve .stl format
zizou1 is on a distinguished road
Hello everyone!
I'm looking for a butterfly valve or a gate valve in .stl format to put inside a cylindric pipe, preferably not completely closed/opened.
Can anyone help me?
Thank you,
Matteo
zizou1 is offline   Reply With Quote
Old   May 15, 2018, 03:39
anonymous
simrego is on a distinguished road
Hi!
Download one model from grabCAD (maybe you can find one there in STEP format), and prepare your stl files. You can do it with salome for example.
simrego is offline   Reply With Quote
Old   May 15, 2018, 04:53
Thank you simrego!
Actually I found various stl valves each of different diameters, but none of the diameter of my pipe: is this a problem for the snappy or is compatible anyway?
Old   May 15, 2018, 06:49
anonymous
If you are doing it for fun, it can be more or less fine. But u could have problems during the snapping process due to the intersecting surfaces (if it is larger than your pipe).
But I still recommend you to find or make an appropriate CAD model and prepare your own .stl files. In salome (It is free, and there are a lot of videos, but you can use any cad software) you can easily extract your surfaces and export them as .stl
If you have a good stl, the snappyhexmesh will be more accurate and faster and etc. So you will be much happier!
Old   May 15, 2018, 07:32
Basically the advice is to import in salome the step file, scale it to the right dimensions and then export as stl file?
Sounds good anyway, thank you.
One more doubt: the diameter of the pipe has to coincide with the internal surface of the valve, hasn't it?
Old   May 15, 2018, 07:49
anonymous
Not really. My advice is to do something like this:
https://www.youtube.com/watch?v=5U7j...l4XW5l9VzlZdKv
Like this, you will have a nice, closed stl surface.
You can find many many examples about the preprocessing on the internet.
Old   May 15, 2018, 08:44
Lovely!
Thank you really helpful!
Old   May 16, 2018, 01:49
Now I've got the stl file, but when I open it with Notepad this is what comes out (attached image).
Do you know why?
Old   May 16, 2018, 02:02
Pablo Higuera
Phicau is on a distinguished road
Hi zizou1,
the STL is in binary format. You can convert it to ascii with a tool like meshlab.
I think that OpenFOAM can work with binary STLs.
Best,
Pablo
Check out my new project: olaFlow --> The olaFlow Support Thread
Phicau is offline   Reply With Quote
Old   May 16, 2018, 04:44
Thank you Pablo!
udf for valve closing a pipe using dynamic mesh chem engineer Fluent UDF and Scheme Programming 2 May 13, 2017 09:39
[CAD formats] .RAW to .stl format!! Saideep OpenFOAM Meshing & Mesh Conversion 5 September 1, 2015 12:15
Modelling an initially closed valve which a fluid opens siw CFX 1 April 26, 2014 06:32
Gate valve flow simulations... nikesh FloEFD, FloWorks & FloTHERM 5 January 28, 2014 01:31
[ICEM] best method to generate surfaces from a .stl file format snudurupati ANSYS Meshing & Geometry 2 July 23, 2009 10:21
