[snappyHexMesh] stl doesn't appear after snappy process
Old   May 18, 2018, 03:50
Default stl doesn't appear after snappy process
zizou1 is on a distinguished road
Hi all,
OF has just finished running the snappy but I can't see my stl file snapped in Paraview.
Theese are the steps I've done:
-copied the stl file in Trisurface folder;
-copied SnappyHexMeshDict and surfaceFeatureExtractDict in the system directory and changed the name of the object;
-started running with Allrun.
Here are the dictionaries:
FoamFile
version 2.0;
format ascii;
class dictionary;
object snappyHexMeshDict;
castellatedMesh true;
snap true;
addLayers false;
geometry
butterflyValve.stl
type triSurfaceMesh;
scale 0.00276;
name butterflyValve;
castellatedMeshControls
maxLocalCells 10000;
maxGlobalCells 200000;
minRefinementCells 10;
maxLoadUnbalance 0.10;
nCellsBetweenLevels 3;
features
file "butterflyValve.eMesh";
scale 0.00276;
level 6;
snapControls
nSmoothPatch 3;
tolerance 2.0;
nSolveIter 30;
nRelaxIter 5;
nFeatureSnapIter 10;
implicitFeatureSnap false;
explicitFeatureSnap true;
multiRegionFeatureSnap false;
addLayersControls
relativeSizes true;
layers
"(lowerWall|butterflyValve).*"
nSurfaceLayers 1;
expansionRatio 1.0;
finalLayerThickness 0.3;
minThickness 0.1;
nGrow 0;
featureAngle 60;
slipFeatureAngle 30;
nRelaxIter 3;
nSmoothSurfaceNormals 1;
nSmoothNormals 3;
nSmoothThickness 10;
maxFaceThicknessRatio 0.5;
maxThicknessToMedialRatio 0.3;
minMedianAxisAngle 90;
nBufferCellsNoExtrude 0;
nLayerIter 50;
writeFlags
scalarLevels
layerSets
layerFields
mergeTolerance 1e-6;
FoamFile
version 2.0;
format ascii;
class dictionary;
object surfaceFeatureExtractDict;
butterflyValve.stl
extractionMethod extractFromSurface;
extractFromSurfaceCoeffs
includedAngle 150;
subsetFeatures
nonManifoldEdges no;
openEdges yes;
writeObj yes;
"Allrun"
#!/bin/sh
cd ${0%/*} || exit 1 # Run from this directory
# Source tutorial run functions
. $WM_PROJECT_DIR/bin/tools/RunFunctions
runApplication surfaceFeatureExtract
runApplication blockMesh
runApplication decomposePar
runParallel snappyHexMesh -overwrite
#- For non-parallel running
#cp -r 0.orig 0 > /dev/null 2>&1
#- For parallel running
ls -d processor* | xargs -I {} rm -rf ./{}/0
ls -d processor* | xargs -I {} cp -r 0 ./{}/0
runParallel patchSummary
runParallel potentialFoam
runParallel $(getApplication)
runApplication reconstructParMesh -constant
runApplication reconstructPar -latestTime
Any ideas of where the mistakes are?
Thanks
zizou1 is offline   Reply With Quote
Old   May 18, 2018, 04:37
anonymous
simrego is on a distinguished road
Hi!
You mean, you wanna see your mesh and stl files together?
Btw I can't see your "locationInMesh" entry in your SHMDict. If you had any errors in your log files please post them.
simrego is offline   Reply With Quote
Old   May 18, 2018, 06:15
snappyHexMesh > log.snappyHexMesh
--> FOAM FATAL IO ERROR:
keyword castellatedMeshControls is undefined in dictionary "D:/blueCFD-Core-2016/ofuser-of4/run/pipe/system/snappyHexMeshDict"
file: D:/blueCFD-Core-2016/ofuser-of4/run/pipe/system/snappyHexMeshDict from line 17 to line 114.
From function const Foam::dictionary& Foam::dictionary::subDict(const Foam::word&) const
in file db/dictionary/dictionary.C at line 642.
FOAM exiting
decomposePar > log.decomposePar
--> FOAM FATAL ERROR:
Case is already decomposed with 4 domains, use the -force option or manually
remove processor directories before decomposing. e.g.,
rm -rf D:/blueCFD-Core-2016/ofuser-of4/run/pipe/processor*
From function int main(int, char**)
in file decomposePar.C at line 393.
FOAM exiting
reconstructParMesh > log.reconstructParMesh
Your current settings specify ASCII writing with 6 digits precision.
Your merging tolerance (1e-007) is finer than this.
Please change your writeFormat to binary or increase the writePrecision
or adjust the merge tolerance (-mergeTol).
in file reconstructParMesh.C at line 516.
FOAM exiting
potentialFoam > log.potentialFoam
keyword potentialFlow is undefined in dictionary "D:/blueCFD-Core-2016/ofuser-of4/run/pipe/system/fvSolution"
file: D:/blueCFD-Core-2016/ofuser-of4/run/pipe/system/fvSolution at line 22.
That's all.
The locationInMesh must be set to any specific coordinates?
Old   May 18, 2018, 06:30
anonymous
There are many errors. First of all i think you miss the closing bracket for the geometry entry in your SHMDict.
The locationInMesh tells shm which part of the mesh should be kept (the stl will cut the domain into 2 or more parts, and you have to mark which one do you want to use)
Also use decomposePar -force, or delete the processor directories before you run decomposePar
And in controlDict set 7 digits precision or decrease your merging tolerance in reconstructParMesh. But if you use reconstructPar -latestTime, you don't need reconstructParMesh before that.
And there are also problems with potentialFoam. I think you should skip this part if you learning openFOAM, and when u understand the basics, you can do more fancy stuff.
For the meshing just run these:
blockMesh
decomposePar -force # -force delete your processor directories if you have.
mpirun -np numberOfProcessors snappyHexMesh -parallel -overwrite #replace numberOfProcessors with the number of processors you have (i mean how much you use)
if it's fine, you can go to the solving phase.
Old   May 18, 2018, 06:45
Talking
Lovely simrego!
I'll go for this and then let's see what happens!
Thanks
Old   May 18, 2018, 10:54
Dear simrego,
this is what comes out after the snappy has been run:
Exec : SnappyHexMesh -parallel -overwrite
Date : May 18 2018
Time : 16:52:57
Host : "PANDI-PC"
PID : 3996
Case : D:/blueCFD-Core-2016/ofuser-of4/run/pipe
nProcs : 4
Slaves :
3
"PANDI-PC.1988"
"PANDI-PC.6348"
"PANDI-PC.3024"
Pstream initialized with:
floatTransfer : 0
nProcsSimpleSum : 0
commsType : nonBlocking
polling iterations : 0
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Read mesh in = 1.017 s
Overall mesh bounding box : (-0.07 -0.07 0) (0.07 0.07 2)
Relative tolerance : 1e-006
Absolute matching distance : 2.009776e-006
butterflyValve.stl : using scale 0.00276
Reading refinement surfaces.
[1]
[3]
[0]
[1]
[3]
[0]
[2]
[1]
[3]
[0]
[2]
[1]
[2]
[3]
[0]
keyword refinementSurfaces is undefined in dictionary "IOstream.castellatedMeshControls"
keyword refinementSurfaces is undefined in dictionary "D:/blueCFD-Core-2016/ofuser-of4/run/pipe/system/snappyHexMeshDict.castellatedMeshControls"
[1]
[2]
[0]
[3]
[1]
file:
[2]
from line
[2]
[3]
0
file:
file:
to line
0
from line
[1]
from line
[1]
0
0
From function
to line
to line
0
0
[1]
in file
[2]
[3]
at line
[2]
[0]
642
[3]
From function
file:
From function
[1]
from line
[3]
FOAM parallel run exiting
33
in file
[1]
to line
49
at line
642
[0]
[3]
[0]
[3]
From function
[0]
in file
[2]
in file
at line
642
at line
job aborted:
[ranks] message
[0] terminated
[1] application aborted
aborting MPI_COMM_WORLD (comm=0x44000000), error 1, comm rank 1
[2] terminated
[3] application aborted
aborting MPI_COMM_WORLD (comm=0x44000000), error 1, comm rank 3
---- error analysis -----
[1,3] on PANDI-PC
SnappyHexMesh aborted the job. abort code 1
Old   May 18, 2018, 12:52
anonymous
In the castellatedMeshControls you miss the refinementSurfaces entry
You need something like this:
refinementSurfaces
        butterflyValve
            // Surface-wise min and max refinement level
            level (5 6);
            // Optional specification of patch type (default is wall). No
            // constraint types (cyclic, symmetry) etc. are allowed.
            //patchInfo
            //   type wall;
            //    inGroups (motorBikeGroup);
You can play with the levels. level (5 6) means the SHM will cut the cells 5 times which intersected by the surface, 6 means it will cut 6 times where the angle is greater than the "resolveFeatureAngle", which entry also missing, i'm not sure if it is needed or it has a default value. You should read this link:
https://cfd.direct/openfoam/user-guide/snappyhexmesh/
Then analize this code and try to understand the meaning of the lines. I think for the begining just replace your dict with this one, and only modify only the following:
https://github.com/OpenFOAM/OpenFOAM...ppyHexMeshDict
castellatedMesh true; // This will cut the cells (you can see in the prev link.), and then u can enable snap if you understand what's happening in the castellation phase, and then enable add layers. I think like this it's easier to understand what's going on in the different phases. Of course later you can do everything for the first time, but i'm not sure if you know what are you doing exactly yet.
snap false;
addLayers false;
geometry { ... };
features { ... };
refinementSurfaces { ... };
refinementRegions { //You can leave it empty now. };
layers { ... };
Then you can play with the parameters and try to understand the meaning of them if they are not clear from the comments.
For the first time snappyHexMesh is a mess for everyone I think. But if you understand the main parts once, it will be much easier.
Sorry for this long post, i hope i wrote something useful for you. I could make the SHMDict for you, but it's better if you figure out yourself. If you feel that you totally lost, just ask me, and I'll try to help you (maybe it's better in private). Good luck!
(And also sorry for my english. )
Old   May 27, 2018, 13:01
Dear simrego,
thank you very much for the time spent for me.
Actually the snappy problem is almost solved. Now i'm trying to run icofoam in the snapped pipe, but at the end of the process Paraview outputs a message saying that the mesh points are much more than the fields (p and U) points/cells. I don't know if the problem is in my code or somewhere else.
Old   May 28, 2018, 06:51
anonymous
As i know it means that you have more (or less) cell data in your p or U files than the mesh has.
A guess:
Before running the icoFoam try to open your case in paraView and load every field variables. If it'll drop the same error, probably you have problems with your initial conditions (ie. using nonuniform bc with more or less data then you need).
Do you have any warnings or errors with icoFoam?
If you have any error in any utility or application please share it.
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 06:01
[snappyHexMesh] Scaling issues with STL file and snappy hex mesh . pradyumnsingh OpenFOAM Meshing & Mesh Conversion 2 July 18, 2018 16:17
[Gmsh] STL on Gmsh + Mesh on Snappy adrieno OpenFOAM Meshing & Mesh Conversion 3 May 20, 2016 12:22
The fl process could not be started because of UDF majid_kamyab Fluent UDF and Scheme Programming 6 December 15, 2015 08:42
[snappyHexMesh] Snappy mesh- stl file Joanna Huang OpenFOAM Meshing & Mesh Conversion 1 January 14, 2013 13:00
