[snappyHexMesh] blockMesh for multi-region snappy
Old   June 7, 2018, 17:19
Default blockMesh for multi-region snappy
kandelabr's Avatar
Nejc
kandelabr is on a distinguished road
I set up a multi-region case, meshing with snappyHexMesh. It seems to do its job but I have problems with outermost faces.
I create a background mesh with blockMesh, leaving the blockMeshDict.boundary empty so that defaultFaces is assigned. Usually I make background mesh just slightly bigger so snappy snaps easily and assigns my 'real' patches.
But in multi-region setup, snappy creates new regions where the cells should have been removed because they were outside my model.
If I make background mesh of exactly the same dimensions than my model (if it's a block, that is), I'm stuck with defaultFaces again.
I could remove domain*/ folders and use changeDictionary and whatnot but I don't think that's the right way to do it.
In the tutorial, blockMesh defines named boundary faces - that's what I can't / don't want to do. Tutorials from holzmann-cfd.com use a mesh created in SALOME...
How do I really set up a multi-region snappyHexMesh?
Thanks!
kandelabr is offline   Reply With Quote
Old   June 12, 2018, 04:45
anonymous
simrego is on a distinguished road
Hi!
What version do you use? In +v1712 (maybe in 1706 and 1612 too) you can define the inside points for the regions you want to keep, and it removes the regions you don't need, and you will have correct boundary names, conform mesh between regions, etc..
simrego is offline   Reply With Quote
Old   June 12, 2018, 05:25
kandelabr's Avatar
Nejc
I'm currently using Turbomachinery CFD's package in which I believe version 5.x is used from OF Foundation. However I'm switching to ESI-CFD's latest version because there's a blended wall function I really need. I'll check snappyHexMesh too and report back.
Thanks!
Old   June 12, 2018, 05:57
anonymous
In v1712 check the $FOAM_UTILITIES/mesh/generation/snappyHexMesh/snappyHexMeshDict file. You will see there how can you define multiple regions with the locationsInMesh entry (i think this part is commented).
Good luck!
multiregion
Maximum number of iterations exceeded chtmultiregionsimpleFoam Moncef OpenFOAM Running, Solving & CFD 28 July 13, 2020 14:26
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 05:07
Floating Point Error with kOmegaSST Turbulence Model shipman OpenFOAM Running, Solving & CFD 5 January 4, 2016 08:57
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
Taking too much for run Grimoli OpenFOAM Running, Solving & CFD 5 November 26, 2013 20:07
