[mesh manipulation] interpolation between two grids of a solver - *** glibc detected *** testFoam: double
Old   June 8, 2018, 01:57
Default interpolation between two grids of a solver - *** glibc detected *** testFoam: double
krishna kant
kk415 is on a distinguished road
Hi Foamers
I am trying to create a solver in which navier-stokes in one grid and temperature is solved in another grid. I developed this solver in a similar fashion to chtMultiRegion. I am stuck in the interpolation function of the solver. I am using the mapping utility of openFoam for this purpose.
I modified the MapConsistentMesh in mapfield.H for my purpose like this:
template<template<class> class CombineOp>
void MapConsistentMesh
const fvMesh& meshSource,
const fvMesh& meshTarget,
const meshToMesh0:rder& mapOrder,
IOobject& T,
IOobject& p,
IOobject& U,
IOobject& Ts,
IOobject& ps,
IOobject& Us
// Create the interpolation scheme
meshToMesh0 meshToMesh0Interp(meshSource, meshTarget);
Info<< nl
<< "Consistently creating and mapping fields for time "
<< meshSource.time().timeName() << nl << endl;
// Search for list of objects for this time
IOobjectList objects(meshSource, meshSource.time().timeName());
objects.add(U);
objects.add(p);
objects.add(T);
Info<< "object size" << objects.size()
<< endl;
// Map volFields
MapConsistentVolFields<scalar>
objects,
meshToMesh0Interp,
mapOrder,
CombineOp<scalar>()
MapConsistentVolFields<vector>
objects,
meshToMesh0Interp,
mapOrder,
CombineOp<vector>()
MapConsistentVolFields<sphericalTensor>
objects,
meshToMesh0Interp,
mapOrder,
CombineOp<sphericalTensor>()
MapConsistentVolFields<symmTensor>
objects,
meshToMesh0Interp,
mapOrder,
CombineOp<symmTensor>()
MapConsistentVolFields<tensor>
objects,
meshToMesh0Interp,
mapOrder,
CombineOp<tensor>()
Info<< " checking1 " << endl;
Info<< " checking " << endl;
// Search for list of target objects for this time
IOobjectList objects(meshTarget, meshTarget.time().timeName());
//objects.add(Us);
//objects.add(ps);
//objects.add(Ts);
// Mark surfaceFields as unmapped
UnMapped<surfaceScalarField>(objects);
UnMapped<surfaceVectorField>(objects);
UnMapped<surfaceSphericalTensorField>(objects);
UnMapped<surfaceSymmTensorField>(objects);
UnMapped<surfaceTensorField>(objects);
// Mark pointFields as unmapped
UnMapped<pointScalarField>(objects);
UnMapped<pointVectorField>(objects);
UnMapped<pointSphericalTensorField>(objects);
UnMapped<pointSymmTensorField>(objects);
UnMapped<pointTensorField>(objects);
// mapLagrangian(meshToMesh0Interp);
The output I am getting is like this :
Starting time loop
Time = 0.005
Solving for fluid region fluid
PISO: Operating solver in PISO mode
Reading transportProperties
fluid
solid
smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 8.90511e-06, No Iterations 19
smoothSolver: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0
DICPCG: Solving for p, Initial residual = 1, Final residual = 0.0492854, No Iterations 12
DICPCG: Solving for p, Initial residual = 0.590864, Final residual = 2.65225e-07, No Iterations 35
Consistently creating and mapping fields for time 0.005
object size3
interpolating T
checking2
interpolating p
checking2
interpolating U
checking2
checking1
*** glibc detected *** testFoam: double free or corruption (out): 0x00007ffc2f2b2fa0 ***
======= Backtrace: =========
/lib64/libc.so.6[0x3b0d275dee]
/lib64/libc.so.6[0x3b0d278c80]
/home/Rajesh/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt64Opt/lib/libOpenFOAM.so(_ZN4Foam12HashPtrTableINS_8IOobject ENS_4wordENS_6string4hashEE5clearEv+0x44)[0x7ffadee37804]
/home/Rajesh/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt64Opt/lib/libOpenFOAM.so(_ZN4Foam12IOobjectListD2Ev+0x9)[0x7ffadee35089]
testFoam[0x4f3564]
testFoam[0x44a2a9]
/lib64/libc.so.6(__libc_start_main+0xfd)[0x3b0d21ed1d]
testFoam[0x44d335]
======= Memory map: ========
00400000-0053c000 r-xp 00000000 08:11 60694501 /home/Rajesh/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt64Opt/bin/testFoam
0073c000-00741000 rw-p 0013c000 08:11 60694501 /home/Rajesh/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt64Opt/bin/testFoam
01e01000-02136000 rw-p 00000000 00:00 0 [heap]
3b0ce00000-3b0ce20000 r-xp 00000000 08:04 29884418 /lib64/ld-2.12.so
3b0d020000-3b0d021000 r--p 00020000 08:04 29884418 /lib64/ld-2.12.so
3b0d021000-3b0d022000 rw-p 00021000 08:04 29884418 /lib64/ld-2.12.so
3b0d022000-3b0d023000 rw-p 00000000 00:00 0
3b0d200000-3b0d38a000 r-xp 00000000 08:04 29884435 /lib64/libc-2.12.so
3b0d38a000-3b0d58a000 ---p 0018a000 08:04 29884435 /lib64/libc-2.12.so
3b0d58a000-3b0d58e000 r--p 0018a000 08:04 29884435 /lib64/libc-2.12.so
3b0d58e000-3b0d590000 rw-p 0018e000 08:04 29884435 /lib64/libc-2.12.so
3b0d590000-3b0d594000 rw-p 00000000 00:00 0
3b0d600000-3b0d617000 r-xp 00000000 08:04 29884442 /lib64/libpthread-2.12.so
3b0d617000-3b0d817000 ---p 00017000 08:04 29884442 /lib64/libpthread-2.12.so
3b0d817000-3b0d818000 r--p 00017000 08:04 29884442 /lib64/libpthread-2.12.so
3b0d818000-3b0d819000 rw-p 00018000 08:04 29884442 /lib64/libpthread-2.12.so
3b0d819000-3b0d81d000 rw-p 00000000 00:00 0
3b0da00000-3b0da02000 r-xp 00000000 08:04 29884533 /lib64/libdl-2.12.so
3b0da02000-3b0dc02000 ---p 00002000 08:04 29884533 /lib64/libdl-2.12.so
3b0dc02000-3b0dc03000 r--p 00002000 08:04 29884533 /lib64/libdl-2.12.so
3b0dc03000-3b0dc04000 rw-p 00003000 08:04 29884533 /lib64/libdl-2.12.so
3b0de00000-3b0de07000 r-xp 00000000 08:04 29884457 /lib64/librt-2.12.so
3b0de07000-3b0e006000 ---p 00007000 08:04 29884457 /lib64/librt-2.12.so
and so on ..... can anyone help me to know from what point this error is coming .... I mean I am getting the output as checking1 is printed. That means upto that point everything is correct. Then at what point the error is occuring????
kk415 is offline   Reply With Quote
Average study of RANS results serrar FLUENT 6 April 26, 2019 12:23
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
EMMS drag model UDF NAD Fluent UDF and Scheme Programming 26 November 19, 2017 07:49
Warning message C4133 while compiling Arminius Fluent UDF and Scheme Programming 0 October 2, 2017 11:44
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 11:34
