[Other] Stting up changeDictionaryDict file for CHT
Old   June 8, 2018, 07:05
Default Stting up changeDictionaryDict file for CHT
Sean Gorry
Sean95 is on a distinguished road
I am working on a CHT model with four regions, I looking for some help with the changeDictionaryDict file. How would I go about setting it up for a particular region based on my U,p,etc files. Below is the U file, everything is either specified as a wall or cyclicAMI in the boundary file. Any help would be greatly appreciated as this is last step before I can run the sim
|  \\    /   O peration     | Version:  plus                                  |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    refractory_to_fluid_domain
        type            noSlip;
	head_can_to_fluid_domain
        type            noSlip;
	heat_acceptor_to_fluid_domain
        type            noSlip;
	refractory_right
        type            cyclicAMI;
	refractory_left
        type            cyclicAMI;
	refractory_exterior
        type            noSlip;
	fluid_domain_right
        type            cyclicAMI;
	fluid_domain_left
        type            cyclicAMI;
	fluid_domain_bottom
        type            noSlip;
    inlet
        type            fixedValue;
        value      	  uniform (-0.35 0 0);
    outlet
        type            zeroGradient;
	heat_acceptor_left
        type            cyclicAMI;
	heat_acceptor_right
        type            cyclicAMI;
	head_can_left
        type            cyclicAMI;
	head_can_right
        type            cyclicAMI;
	head_can_to_interior_heat_acceptor
        type            noSlip;
	head_can_interior
        type            noSlip;
	head_can_bottom
        type            noSlip;
Sean95 is offline   Reply With Quote
Old   June 27, 2018, 13:08
kandelabr's Avatar
Nejc
kandelabr is on a distinguished road
It's in the snappyMultiRegionHeater tutorial: https://github.com/OpenFOAM/OpenFOAM...DictionaryDict
Check changeDictionaryDicts for other regions as well.
Also a useful tool for setting up CHT cases is about to be released with a new version but for now you can use templates in the -dev version. They are very helpful even without the setup tool: https://github.com/OpenFOAM/OpenFOAM...singleFluidCHT
kandelabr is offline   Reply With Quote
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 21:03
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
