[Gmsh] 3D Hex Mesh after BooleanDifference in Gmsh
Old   June 28, 2018, 08:39
Default 3D Hex Mesh after BooleanDifference in Gmsh
Bhargav lakhlani
bhargav1195 is on a distinguished road
Hello Everyone,
I am trying to generate a structured mesh for a rectangular domain with one Inlet and one Outlet. I have bolleaned(Cut) the Inlet and Outlet from the main rectangular domain. (Computational Domain is attached in Figure). After creating one volume, Transfinite Volume function is not working in Gmsh as it requires Volume with 5 or 6 faces only. However, if I try with TransfQuadTri function still I am unable to create 3D Hex mesh of Domain.
The script of above operation is as follow:
SetFactory("OpenCASCADE");
Box(1) = {0, 0, 0, 10, 10, 10};
Box(2) = {0.5, 0.5, 0.5, 0.2, 2, 2};
Box(3) = {9, 7.5, 7.5, 0.2, 2, 2};
BooleanDifference{ Volume{1}; Delete; }{ Volume{2}; Delete; }
BooleanDifference{ Volume{1}; Delete; }{ Volume{3}; Delete; }
Physical Surface("Inlet") = {30};
Physical Surface("Outlet") = {13};
Physical Surface("wall") = {22, 19, 23, 24, 20, 21};
Physical Volume("Domain") = {1};
Transfinite Line "*" = 10;
Transfinite Surface "*";
Recombine Surface "*";SetFactory("OpenCASCADE");
Transfinite Volume "*";
Please suggest me some feasible solution to this problem.
Regards,
Bhargav
bhargav1195 is offline   Reply With Quote
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[blockMesh] Openfoam: Meshing, where do my defaultFaces come from syntex OpenFOAM Meshing & Mesh Conversion 19 December 10, 2018 07:21
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[blockMesh] BlockMesh number internal faces and boundary ynos OpenFOAM Meshing & Mesh Conversion 6 December 13, 2011 05:36
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
