[blockMesh] Difficulty creating internal faces
Old   August 19, 2018, 15:38
Default Difficulty creating internal faces
salomama is on a distinguished road
Hello everyone
i tried to create two walls as internal faces in blockmeshdict but i faced lot of errors so i searched and i found many many complicated ways to do it but the easiest was tat below quoted (i attached also the first case and second that i am working on now)
so my problem even when creating the new case i still get an error, but different this time.
first time i used to get this error
#Trying to specify a boundary face 4(7 19 20 8) on the face on cell 3 which is either an internal face or already belongs to some other patch. This is face 0 of patch 6 named walls.
but now i get this one
#face 0 in patch 6 does not have neighbour cell face: 4(18 20 28 26)
i really don't know what i am doing wrong!
i am attaching my first blockmeshdict and the new one that i am working on.
first one;
Show quoted text
new one;
vertices
(0 0 0) //0
(1.19 0 0)
(0 0.5 0) //2
(1.19 0.5 0) //3
(0 0.91 0)
(1.49 0.91 0) //5
(0 1.21 0)
(1.49 1.21 0) //7
(0 0 0.1)
(1.19 0 0.1)
(0 0.5 0.1)
(1.19 0.5 0.1) //11
(0 0.91 0.1)
(1.49 0.91 0.1)
(0 1.21 0.1) //14
(1.49 1.21 0.1) //15
(1.19 0 0) //16
(1.5 0 0) //17
(1.19 0.5 0)
(1.5 0.5 0)
(1.49 0.91 0)
(1.5 0.91 0) //21
(1.49 1.21 0)
(1.5 1.21 0) //23
(1.19 0 0.1)
(1.5 0 0.1) //25
(1.19 0.5 0.1)
(1.5 0.5 0.1) // 27
(1.19 0.91 0.1)
(1.5 0.91 0.1) //29
(1.49 1.21 0.1)
(1.5 1.21 0.1) //31
blocks
hex (0 1 3 2 8 9 11 10) (10 10 1) simpleGrading (1 1 1)
hex (2 3 5 4 10 11 13 12) (10 10 1) simpleGrading (1 1 1)
hex (4 5 7 6 12 13 15 14) (10 10 1) simpleGrading (1 1 1)
hex (16 17 19 18 24 25 27 26) (10 10 1) simpleGrading (1 1 1)
hex (18 19 21 22 26 27 29 28) (10 10 1) simpleGrading (1 1 1)
hex (20 21 23 22 28 29 31 30) (10 10 1) simpleGrading (1 1 1)
edges
boundary
inlet
type patch;
faces
(4 12 14 6)
outlet
type patch;
faces
(21 23 31 29)
leftside
type patch;
faces
(0 8 10 2)
(2 10 12 4)
righttside
type patch;
faces
(19 21 29 27)
(17 19 27 25)
symmetry
type patch;
faces
(6 14 15 7)
(22 30 31 23)
farfield
type patch;
faces
(0 1 9 8)
(16 17 25 24)
walls
type wall;
faces
(18 20 28 26)
(21 20 28 29)
frontAndBack
type empty;
faces
(0 2 3 1)
(2 4 5 3)
(4 6 7 5)
(8 9 11 10)
(10 11 13 12)
(12 13 15 14)
(16 18 19 17)
(18 20 21 19)
(20 22 23 21)
(24 25 27 26)
(26 27 29 28)
(28 29 31 30)
mergePatchPairs
The situation:
ext1 int ext2
should be created as:
ext1 int1int2 ext2
which is achieved by duplicating the vertices that make up the internal patch,
such that you do not create two faces with the same set of vertices.
That would be ambiguous!
salomama is offline   Reply With Quote
Old   August 19, 2018, 15:45
attached the pictures of my cases
#blockmeshdict
[snappyHexMesh] Layers not growing at all zonda OpenFOAM Meshing & Mesh Conversion 12 June 6, 2020 11:28
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
foam-extend_3.1 decompose and pyfoam warning shipman OpenFOAM 3 July 24, 2014 08:14
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
