November 6, 2018, 04:36 |
wind around building
Daniel
Rep Power: 7 |
I am trying to set up a case like wind around building tutorial in simple foam. I changed the file to my own an left everything to default. when I run the case in paraview instead of seeing the result of snappyHexMesh I get my own mesh and somehow the case fails. I can't find whats wrong with my case? would anybody mind helping me? I', really stuck. Any help would be appreciated. This is the Linke to the files of the case: http://www.mediafire.com/file/5do1fh...ase-1.rar/file |
November 27, 2018, 00:26 |
Abe
Rep Power: 9 |
Hey,
I think your problem is that your "locationInMesh" specifies a point internal to your stl geometry, and from what you wrote it seems like you meant for the mesh to be external. Its really worth it to spend some time with the tutorials before you try to run your own cases - much less frustrating that way, but it takes a lot of time: https://wiki.openfoam.com/Tutorials |
#mesh #snappyhexmesh |
[foam-extend.org] Error compiling OpenFOAM-1.6-ext | Canesin | OpenFOAM Installation | 137 | January 20, 2016 14:56 |
Wind on building simulation | cedrik | OpenFOAM Running, Solving & CFD | 14 | December 17, 2014 04:21 |
wind tunnel results for building pressures | danijela.djuric.mijovic | Main CFD Forum | 0 | April 4, 2014 09:50 |
something wrong in tutorial of simulation of wind around building... | teguhtf | ANSYS | 0 | December 11, 2010 18:53 |
Compilation error OF1.5-dev on Suse10.3 | darenyang | OpenFOAM Installation | 0 | April 29, 2009 04:55 |
