[mesh manipulation] Using extrudeMesh to create an axisymmetric mesh yields a wrongOrientedFace |
Tony
Rep Power: 10 ![]() |
Hi everyone,
I am currently trying to create an axisymmetric mesh for a project. I am following steps similiar to those performed by Tobi which he generously shares on his webpage, but instead of using snappyHexMesh to generate the mesh before extruding I am using GridPro. (I prefer a structured mesh rather than cut-cell). I am running into an issue though, after I use extrudeMesh, checkMesh says I have 1 wrongOrientedFace. Inspecting the file and confirming with foamToVTK, this face is the axis. I have tried recreating the mesh in several different densities in hopes that the single face was just a odd result, but it appears consistently. I have also tried manually re-orienting the face by editing the order of the points in the faces file, but that just resulted in a new checkMesh error. Would anyone have any tips on how I may resolve this wrongOrientedFace issue? |
axis-symmetric, check mesh, extrude mesh |
[mesh manipulation] Does extrudeMesh affect mesh quality in non extruded cells? | Blanco | OpenFOAM Meshing & Mesh Conversion | 3 | February 25, 2023 08:19 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
[gmsh] How to create a 3D volume mesh using a existing surface mesh?! | RobertHB | Mesh Generation & Pre-Processing | 0 | July 20, 2017 08:12 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 01:07 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
