[Other] Definations of CellZone, FaceZone, CellRegion |
May 4, 2016, 08:27 |
Janry
Rep Power: 10 |
Hi dear foamers,
I am a beginner in OpenFOAM simulation. Now I'm getting quite anxious with the defination of : Cellzone, Facezone, Cellregion Setset, Cellset..... Could anyone help me to get out from them? I'm really no idea what do they mean.... Thanks! Janry |
May 4, 2016, 10:48 |
Rep Power: 10 |
Hey,
If you begin with OpenFOAM, my best advice is to read the most you can the powerpoints presentations at this adress. And for your meshing questions, you will more precisely see the lesson called " Meshing using OpenFOAMŪ technology " on Module 3. I hope it will help you, all these slides were almost the only way for me to understand anything with openfoam ! |
May 4, 2016, 20:49 |
#3 | |
Janry
Rep Power: 10 |
Thanks for your direction! I'll download it and have a detail reading! Thanks again! Janry |
May 5, 2016, 15:31 |
Alex
Rep Power: 21 |
Hi Janry,
If you have some doubt about the use of "topoSet" utility and the definition of the "cellSets" and "cellZones" you can take a look at my web site where I have some basic multiregion tutorials explained in detail. I hope it can help you a little bit. Bst regards, Alex
Web site where I present my Master's Thesis: foamingtime.wordpress.com The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in! |
May 7, 2016, 01:36 |
Janry
Rep Power: 10 |
Hi Zfaraday,
Thanks for your information. I've just read your website, that helps me understand the cellzone. However, i'm still quite confuse about difference between the following definations: cellSets, faceSets, pointSets, cellZoneSet, cellzone, facezone, cellregion... Could you give me some more advices about those definations? Thanks a lot! Janry |
September 28, 2016, 18:00 |
#6 | |
Tom Dylan
Rep Power: 10 |
I am trying to set up a groundwaterFoam suGWFoam with different regions, and your expanations show me tha way Excelente, 1000 gracias! Tom |
September 29, 2016, 11:25 |
#7 | |
Alex
Rep Power: 21 |
Best regards, Alex
February 1, 2018, 03:58 |
ppt are gone TT
#8 | |
Paul Palladium
Rep Power: 10 |
I am looking for the same ressources. I am playing with baffles and I would like to understand the differences between cellZonce, faceZone, cellRegion.. Can someone provide me useful links ? F |
December 14, 2018, 16:20 |
#9 | |
Utkun Malkocoglu
Rep Power: 9 |
I know I am too late, but I can not access the pdf "Meshing using OpenFOAMŪ technology" at the link you shared. It seems the pdf is removed or moved somewhere else. Would you mind if I request its physical copy (if you have)? If not, could you suggest another resource about this issue? Thanks in advance. |
December 17, 2018, 12:39 |
#10 |
Utkun Malkocoglu
Rep Power: 9 |
Is not there anybody here to help me about this topic and multi-region meshing?
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[snappyHexMesh] SHM doesn't create cellZones for one region | Eko | OpenFOAM Meshing & Mesh Conversion | 10 | January 24, 2018 02:03 |
Problem of creating only cellZone (no faceZone) using snappyHexMesh | wc34071209 | OpenFOAM Pre-Processing | 5 | November 16, 2015 20:58 |
faceZone or cellZone for MRF | nash | OpenFOAM Pre-Processing | 2 | April 30, 2015 12:06 |
