[blockMesh] Problem with face matching
Like Tree1Likes
  • 1 Post By aow
Old   February 14, 2019, 09:00
Default Problem with face matching
Alejandro
Alejandro_Dominguez is on a distinguished road
Hello, first of all this is my first question in the forum so I apologise for any mistake I can make.
I am trying to create a 3D C-grid with blockMesh to use it as background mesh in snappyHexMesh, and I have almost succeeded except for a problem with face matching. To create it, I have divided the domain in 2 quarters of cylinders and 1 prism, but the problem is that blockMesh sets as defaultFaces the face between the prism and the two quarters and this is a face I expected that blockMesh would ignore. When I tried to use mergePatchPairs as an alternative I got an error message about no cell neighbours faces.
I attatch the blockMeshDict and an Image of the C-grid side with the problematic face outlined in red.
Does anyone know how to remove that defaultFace or how to correct my blockMeshDict so this problem does not appear?
HTML Code:
|  \\    /   O peration     | Version:  v1812                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
vertices
    (74 844.8 0)//0
	(-770.8 0 0)//1
	(74 -844.8 0)//2
	(74 844.8 30)//3
	(-770.8 0 30)//4
	(74 -844.8 30)//5
	(74 0 0)//6
	(74 0 30)//7
	(844.8 -844.8 0)//8
	(844.8 844.8 0)//9
	(844.8 844.8 30)//10
	(844.8 -844.8 30)//11
blocks
    hex (1 2 6 6 4 5 7 7) (20 20 2) simpleGrading (1 1 1) //cuarto de cilindro
	hex (0 1 6 6 3 4 7 7) (20 20 2) simpleGrading (1 1 1) //cuarto de cilindro
	hex (0 2 8 9 3 5 11 10) (30 15 2) simpleGrading (1 1 1) //cubo (30 celdas en y 15 en x )
edges
	arc 1 2 (-523.3638087 -597.3638087 0)
	arc 0 1 (-523.3638087 597.3638087 0)
	arc 4 5 (-523.3638087 -597.3638087 30)
	arc 3 4 (-523.3638087 597.3638087 30)
boundary
    inlet
        type patch;
        faces
            (5 4 1 2)
			(4 3 0 1)
    outlet
        type patch;
        faces
            (8 9 10 11)
    frontAndBack
        type symmetry;
        faces
			(3 4 7 7)
			(4 5 7 7)
			(5 11 10 3)
			(2 1 6 6)
			(1 0 6 6)
			(0 9 8 2)
	topAndBottom
        type wall;
        faces
            (3 10 9 0)
			(5 2 8 11)
mergePatchPairs
	//(  ) merge patch pair 0
blockMeshDict.txt
Thank you!!
Alejandro_Dominguez is offline   Reply With Quote
Old   March 2, 2019, 14:08
aow
Andrew O. Winter
aow is on a distinguished road
I would try splitting the third hex you’re trying to create into two separate hexes along the line y = 0. As far as I know, you can’t create a hex that has a face connected to 2 faces of 2 different hexes.
So you would need to add an additional pair of vertices...
(844.8 0 0) //12
(844.8 0 30) //13
split the third hex into...
hex(0 6 12 9 3 7 13 10)
hex(6 2 8 12 7 5 11 13)
Of course you would also need to edit the boundaries appropriately too. Note I have not actually run your blockMeshDict to check my edits (I’m using my phone to write to you), but I believe this approach is the correct one to take. Good luck!
aow is offline   Reply With Quote
blockmesh, facematching, mergepatchpairs
[ICEM] Error in mesh writing helios ANSYS Meshing & Geometry 21 August 19, 2021 14:18
Problem with 'Mapped Face Meshing' RobertW FLUENT 0 November 19, 2016 15:39
[snappyHexMesh] Error while running SnappyHex in parallel mg.mithun OpenFOAM Meshing & Mesh Conversion 1 February 10, 2016 13:13
[Commercial meshers] Face ordering problem for nonrectangular cyclic boundary conditions cfdmarkus OpenFOAM Meshing & Mesh Conversion 3 August 17, 2011 15:07
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 22:50
