March 28, 2019, 08:26 |
Multi Layers SnappyHexMesh
Edoardo
Rep Power: 7 |
Good Morning everybody,
I am Edoardo and I am currently working on the Ahmed Body. Right now I am trying to give different setting for the layers in snappy but I do not know why nothing happened; it seems like the local parameters that I gave to in the Dict were not red. In particular I want to give different layer specification ( such as n of layers, expansion ratio and the final layer thickness) to different patches. I hope it is possible to do that in snappy. This is what I wrote in my snappyDict for the layers: addLayersControls { // Are the thickness parameters below relative to the undistorted // size of the refined cell outside layer (true) or absolute sizes (false). relativeSizes true; //GLOBAL PARAMETERS // Expansion factor for layer mesh expansionRatio 1.3; // Wanted thickness of final added cell layer. If multiple layers // is the thickness of the layer furthest away from the wall. // Relative to undistorted size of cell outside layer. // See relativeSizes parameter. finalLayerThickness 0.53; // Minimum thickness of cell layer. If for any reason layer // cannot be above minThickness do not add layer. // Relative to undistorted size of cell outside layer. minThickness 0.08; // Per final patch (so not geometry!) the layer information layers { "Ahmed_patch0|Ahmed_patch2|Ahmed_patch4|Ahmed_patc h6|Ahmed_patch8|Ahmed_patch9|" { //LOCAL PARAMETERS nSurfaceLayers 5; expansionRatio 1.3; finalLayerThickness 0.53; } "groundWall" { //LOCAL PARAMETERS nSurfaceLayers 5; expansionRatio 1.3; firstLayerThickness 0.09; } } Thanks in advance, Edoardo. |
March 28, 2019, 10:03 |
Lucky
Rep Power: 66 |
As a workaround, you can try running snappy more than once, each time with a different snappyHexMeshDict.
layer addition, openfoam, snappy hex mesh |
[snappyHexMesh] Triangular elements in boundary layers generated by snappyHexMesh | mike.franky | OpenFOAM Meshing & Mesh Conversion | 0 | June 3, 2018 09:46 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
[snappyHexMesh] 2D snappyHexMesh with layers | grjmell | OpenFOAM Meshing & Mesh Conversion | 2 | May 27, 2013 12:00 |
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh | Elise | OpenFOAM Meshing & Mesh Conversion | 1 | April 22, 2013 02:32 |
[snappyHexMesh] SnappyHexMesh doesn't succeed in adding several layers | eti0123456789 | OpenFOAM Meshing & Mesh Conversion | 5 | April 9, 2013 02:36 |
