[snappyHexMesh] failed refinement for some stls
Old   April 15, 2019, 22:00
Default failed refinement for some stls
Yehezkiel Wiliardy
yewi is on a distinguished road
Hi foamers,
I tried to do snappy but some part of the STL did not get refined as wanted.I tried to split the STL into each solid STL but did not work. One instance that worked was if the cylinder are faced downwards. However, I wanted these cylinder to face at an angle.
Anyone has any idea of what went wrong and how to fix the snappyHexMesh
Referring to the attached images, the failed refinement areas and the STL model supplied.
Also the snappyHexMeshDict attached. Thank you in advance
yewi is offline   Reply With Quote
snappyhexmesh
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 03:35
Initial conditions for uniform flow andreas OpenFOAM 5 November 16, 2012 15:00
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 09:54
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
