[snappyHexMesh] How do I put STL files in interFoam?
Old   January 12, 2021, 03:12
Default How do I put STL files in interFoam?
seo
smj7467 is on a distinguished road
Hello. It's only been a week since I learned Openfoam.
I am currently doing a tutorial using the dambreak in the interFoam.
I have a question.
The tutorial contains blockmesh of dambreak, but I would like to use Solidworks and STL files to add mesh directly.
I don't know even if I look for several videos.
Could you tell me how to put the STL file into the interfoam easily?
Or do you have a tutorial?
smj7467 is offline   Reply With Quote
Old   January 13, 2021, 10:06
37269 is on a distinguished road
You can use snappyHexMesh for that. It's shown for example in the motorBike tutorial.
37269 is offline   Reply With Quote
#interfoam #dambreak #stl
[mesh manipulation] topoSet for stl files Owais Shabbir OpenFOAM Meshing & Mesh Conversion 4 November 8, 2020 17:42
[snappyHexMesh] With FreeCAD: creating waterproof STL files? robob OpenFOAM Meshing & Mesh Conversion 11 April 29, 2018 11:33
k-e & GAMG interFoam Schemitisation Stability Issue JFM OpenFOAM Running, Solving & CFD 3 December 1, 2015 05:58
How to create inlet/outlet/wall STL files from a STL CAD model Gentible Mesh Generation & Pre-Processing 1 June 23, 2015 10:18
[snappyHexMesh] Convert stl files and multi region abrunet OpenFOAM Meshing & Mesh Conversion 1 July 1, 2014 10:15
