[blockMesh] blockMesh fails with Foam::error::printStack
Like Tree2Likes
  • 1 Post By Orgogozo
Old   August 18, 2019, 11:46
Default blockMesh fails with Foam::error::printStack
Axel
Illmatic is on a distinguished road
I am trying to generate a mesh using blockMesh. My blockMeshDict looks like this:
|  \\    /   O peration     | Version:  plus                                  |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
scale   0.001;
hVol 400;
lVol 600;
x1 150;
y1 210;
x2 150;
y2 150;
x3 210;
y3 210;
nBlock1XCells 3000;
nBlock1YCells 1200;
nBlock2XCells 7800;
nBlock2YCells 1200;
nBlock3XCells 3000;
nBlock3YCells 3800;
nBlock4XCells 1200;
nBlock4YCells 3800;
nBlock5XCells 7800;
nBlock5YCells 3800;
nBlock6XCells 3000;
nBlock6YCells 3000;
nBlock7XCells 7800;
nBlock7YCells 3000;
vertices
    (0 $y2 0)			//0
    ($x2 $y2 0)			//1
    ($x2 $y2 0)			//2
    ($lVol $y2 0)			//3
    (0 $y1 0)		//4
    ($x1 $y1 0)		//5
    ($x3 $y3 0)		//6
    ($lVol $y3 0)		//7
    (0 $hVol 0)			//8
    ($x1 $hVol 0)		//9
    ($x3 $hVol 0)		//10
    ($lVol $hVol 0)			//11
    (0 $y2 0.5)		//12
    ($x2 $y2 0.5)		//13
    ($x2 $y2 0.5)		//14
    ($lVol $y2 0.5)		//15
    (0 $y1 0.5)		//16
    ($x1 $y1 0.5)	//17
    ($x3 $y3 0.5)	//18
    ($lVol $y3 0.5)		//19
    (0 $hVol 0.5)		//20
    ($x1 $hVol 0.5)		//21
    ($x3 $hVol 0.5)		//22
    ($lVol $hVol 0.5)		//23
	(0 0 0)			//24 Part of floor patch
	(0 0 0.5)		//25 Part of floor patch
	($x2 0 0)			//26 Part of floor patch
	($x2 0 0.5)		//27 Part of floor patch
	($lVol 0 0)			//28 Part of floor patch
	($lVol 0 0.5)		//29 Part of floor patch
blocks
    hex (0 1 5 4 12 13 17 16) ($nBlock1XCells $nBlock1YCells 1) simpleGrading (1 1 1)
    hex (1 3 7 6 13 15 19 18) ($nBlock2XCells $nBlock2YCells 1) simpleGrading (1 1 1)
    hex (4 5 9 8 16 17 21 20) ($nBlock3XCells $nBlock3YCells 1) simpleGrading (1 1 1)
    hex (5 6 10 9 17 18 22 21) ($nBlock4XCells $nBlock4YCells 1) simpleGrading (1 1 1)
    hex (6 7 11 10 18 19 23 22) ($nBlock5XCells $nBlock5YCells 1) simpleGrading (1 1 1)
	hex (24 26 1 0 25 27 13 12) ($nBlock6XCells $nBlock6YCells 1) simpleGrading (1 1 1)
	hex (26 28 3 1 27 29 15 13) ($nBlock7XCells $nBlock7YCells 1) simpleGrading (1 1 1)
edges
boundary
	inlet
		type patch;
		faces
			(24 25 12 0)
			(0 12 16 4)
			(4 16 20 8)
	outlet
		type patch;
		faces
			(28 29 15 3)
			(3 15 19 7)
			(7 19 23 11)
	triangle
		type wall;
		faces
			(1 13 17 5)
			(5 17 18 6)
			(6 18 13 1)
	upperWall
		type wall;
		faces
			(8 20 21 9)
			(9 21 22 10)
			(10 22 23 11)
	lowerWall
		type wall;
		faces
			(24 25 27 26)
			(26 27 28 29)
mergePatchPairs
Now when I try to create the blockMesh I get the following error message:
Creating polyMesh from blockMesh
Creating patches
Creating cells
Creating points with scale 0.001
    Block 0 cell size :
        i : 5e-05 .. 5e-05
        j : 5e-05 .. 5e-05
        k : 0.0005 .. 0.0005
    Block 1 cell size :
        i : 5.76923e-05 .. 5.76923e-05
        j : 7.07107e-05 .. 7.07107e-05
    Block 2 cell size :
        i : 5e-05 .. 5e-05
        j : 5e-05 .. 5e-05
    Block 3 cell size :
        i : 5e-05 .. 5e-05
        j : 5e-05 .. 5e-05
    Block 4 cell size :
        i : 5e-05 .. 5e-05
        j : 5e-05 .. 5e-05
    Block 5 cell size :
        i : 5e-05 .. 5e-05
        j : 5e-05 .. 5e-05
#0  Foam::error::printStack(Foam::Ostream&) addr2line failed
#1  Foam::sigSegv::sigHandler(int) addr2line failed
#2  ? addr2line failed
#3  Foam::blockMesh::createPoints() const addr2line failed
#4  Foam::blockMesh::points() const addr2line failed
#5  ?
#6  __libc_start_main addr2line failed
#7  ?
Segmentation fault (core dumped)
What is causing this this error and how can I resolve this?
Illmatic is offline   Reply With Quote
Old   August 22, 2019, 04:50
Muhammad Waqas
mwaqas is on a distinguished road
Send a message via Skype™ to mwaqas
Cań you please post the complete error message. This error message is not telling anything.
BR
mwaqas is offline   Reply With Quote
Old   September 17, 2019, 09:47
Laurent Orgogozo
Orgogozo is on a distinguished road
Dear foamers,
I also met such a 'printStack error' while trying to build a mesh with OpenFOAM_v6 ; the same mesh was built without problem with OpenFOAM_v1806. You will find below the error message, and in attachment the associated blockMeshDict as well as the log of the blockMesh command execution.
Does anyone have a clue about this problem ?
Error message :
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigSegv::sigHandler(int) at ??:?
#2 ? in "/usr/lib64/libc.so.6"
#3 __intel_avx_rep_memset at ??:?
#4 Foam:olyMesh::initMesh(Foam::List<Foam::cell>&) at ??:?
#5 Foam:olyMesh:olyMesh(Foam::IOobject const&, Foam::Xfer<Foam::Field<Foam::Vector<double> > > const&, Foam::List<Foam::cellShape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::PtrList<Foam::dictionary> const&, Foam::word const&, Foam::word const&, bool) at ??:?
#6 ? at ??:?
#7 __libc_start_main in "/usr/lib64/libc.so.6"
#8 ? at ??:?
/var/spool/slurmd/job266413/slurm_script : ligne 15 : 36516 Erreur de segmentation blockMesh > logBlockMesh_v6_boundary
Orgogozo is offline   Reply With Quote
Old   September 18, 2019, 10:55
Muhammad Waqas
I used your blockMeshDict and it ran without any problem. I just reduced the number of elements. You can see the mesh in attachment.
hex (0 1 2 3 4 5 6 7) (100 320 40) simpleGrading (1 1 0.00865240653108278)
hex (1 8 9 2 5 10 11 6) (40 320 40) simpleGrading (1 1 0.00865240653108278)
hex (8 12 13 9 10 14 15 11) (100 320 40) simpleGrading (1 1 0.00865240653108278)
The problem might be because of the memory of your system. It is looking like a very fine mesh
With your original grading, you would have 260 millions cells (do you really have that big machine). The current mesh (that I have attached below) is having 3 million cells.
As far as I remember, as a rule of thumb, 1.5G RAM is required for 1 million element.
PS: I used OFv1906 for meshing
BR
Old   September 19, 2019, 04:22
Laurent Orgogozo
Dear mwaqas,
The problem should not be the memory of the used system : I made the run on a fat node with 1.5 TB RAM. Moreover, this exact blockMeshDict with ~260 millions of cells is succesfully used with OpenFOAM_v1806 on the same system, while it leads to the reported error when used with OpenFOAM_v6. Nevertheless, I made the test with OpenFOAM_v6 and a smaller mesh, and the blockMesh commands did work in that smaller case. So their is a mystery there that right now I cannot understand. I'll try to figure out what's going on with the administrators of the used supercomputer, but if you have ideas of what could explain this trouble please let me now !
Best regards,
Laurent Orgogozo
mwaqas likes this.
Old   September 24, 2019, 09:13
Laurent Orgogozo
Dear Muhammad, dear foamers,
After verification with my colleagues from the CALMIP supercomputing center, it is likely that the encountered problem is related to a new bug with blockMesh in OpenFOAM_v6. I recall that this mesh is successfully built with OF_v1806, and lead to a 'printStack error' while trying to be built with OpenFOAM_v6. Nevertheless the mesh built with OF_v1806 is usable for computation with OF_v6. Still, if someone solve out this issue, please let me know!
Kind regards,
Laurent Orgogozo
mwaqas likes this.
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 bjdarrer OpenFOAM Installation 7 August 25, 2020 19:15
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
[blockMesh] blockMesh (of 2.3.1) fails for wedge josefrito OpenFOAM Meshing & Mesh Conversion 0 February 8, 2015 08:10
blockMesh with Foam::error::printStack sontac OpenFOAM 1 February 22, 2012 03:32
[blockMesh] blockMesh Fails to be Recognized AustinK OpenFOAM Meshing & Mesh Conversion 0 January 20, 2010 09:44
