[Salome] Unwanted face inside a geometry made with IdeasUnvToFoam
Old   November 8, 2019, 09:01
Unhappy Unwanted face inside a geometry made with IdeasUnvToFoam
20mioMeshGiant
HelpMeWithThisMeshGuysPlx is on a distinguished road
Dear CFD-Online users
I have a terrible problem with mesh made in Salome, converged to OF format via IdeasUnvToFoam. After the conversion I can see an additional, unwanted face inside the internal cells. It means I have a totally unnecessary face in the middle of a valve which should be empty inside. Please see the attached photo.
Do you have any ideas how to deal with this problem? It would be perfect to make them "transparent" in terms of boundary conditions, so the faces don't have any specific boundary conditions or even becomes part of internal mesh.
I tried to make them "empty" but it solves the case in only one direction.
Any tips how to get rid of this face "defaultFaces"?
HelpMeWithThisMeshGuysPlx is offline   Reply With Quote
Old   November 10, 2019, 04:29
Damian Berghof
virengos will become famous soon enough
Dear HelpMeWithThisMeshGuysPlx,
there is no attached photo!
And usually such magic faces are being created by human hand in Salome (based on personal experience). Can you upload please some pictures showing your Salome model or even upload your entire Salome model, if possible? I can investigate it.
best,
Damian
Get more support about Meshing with Salome and Visualization with ParaView in my growing groups
https://bit.ly/2lFfDkQ
https://bit.ly/2k2u8Pj
virengos is offline   Reply With Quote
Old   November 10, 2019, 05:03
20mioMeshGiant
Thank you for your Reply, Damian
this is the .py file made with Salome (just the extension changed to .txt)
Best Regards
EDIT: case solved
ideasunvtofoam, openfoam, salome
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
