Tommaso M.
Rep Power: 7 ![]() |
Hi All,
I am new in OpenFOAM and I was asked to create the mesh of a converging-diverging nozzle. I tried with blockMesh but I found it difficult in creating curved surfaces. I know that other tools exist, like Gmsh, Salome, SnappyHexMesh, and so on, but I don't know which is the best mesh tool for my problem. Do you have any advice, please? Thanks! TommyM |
Kmeti Rao
Rep Power: 8 ![]() |
Hi Tommy,
you can go through these tutorials for blockmesh http://www.wolfdynamics.com/wiki/mes..._blockmesh.pdf. I would also suggest you to have a look into cfMesh, during my early days I found cfMesh was little straight forward and easy to learn compared to snappyHexMesh. Both are great tools! K. Rao |
Carlo_P
I think that with snappy would be very easy if you have the .stl file.
You can use every standard setup. |
Tommaso M.
Hi Carlo,
I would like to use snappyHexMesh, but I'm not able to generate the .stl file properly from the CAD file. I generate my geometry with SolidWorks but I can't define the patches (like inlet, outlet, walls) in the file, which are necessary in snappy. How can I do this? Thanks for your reply. |
Tommaso M.
Hi Krao,
I have some basic knowledge about snappyHexMesh because I used it for a university class, where the professor gave me the .stl file. Unfortunately, now I don't have the .stl file and I have to generate it. Anyway, if I fail with snappy, I will try with cfMesh. Thanks for your reply. |
Carlo_P
Hey, in every mesher you have to define the patches.
One solution is to divide in the CAD the surfaces, creting different stl files and using surfaceToPatch after you do the mesh: https://www.openfoam.com/documentati...ceToPatch.html or otherwise, you can use surfaceSplitByAngle. It split by a particolar angle the surface. In this way you can have your patch splitted. I think you have to perform this before meshing. Try.. |
Carlo_P
If you want, you can also try this softwware Helyx-Os, that provide a GUI for openFOAM and snappy.
It would be easier to mesh there. |
Tommaso M.
I succeeded in creating .stl file from GMSH but then I used snappy for the mesh. It sounds strange, but I'm not able to properly "control" the mesh generation in GMSH (using GUI).
Again, thank you all for your help! |
A high order curvilinear mesh generation(converting) tool is strongly recommended | hyperman | Main CFD Forum | 2 | August 7, 2018 17:30 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
