[mesh manipulation] Cylinder mesh - need for suggestions |
October 22, 2019, 12:45 |
Maveryck Andres
Rep Power: 7 |
Hi everyone
currently I'm working on turbulence simulation with k-epsilon model over a cylinder channel. I'm getting a wird plot for all the variables and I'm pretty sure is because of the mesh, as you can see on the attached images the wird values of variable k are exactly located over the edges of the central block so I suspect there has to be a better way to mesh. Any suggestion will be welcome k.png Mesh.jpg |
October 23, 2019, 01:47 |
Damian Berghof
Rep Power: 10 |
Hi Maveryck,
can you provide some more details? - boundary conditions, model definition? - geometry size, dimensions and scaling ok ? best, Damian
Get more support about Meshing with Salome and Visualization with ParaView in my growing groups https://bit.ly/2lFfDkQ https://bit.ly/2k2u8Pj |
October 23, 2019, 04:46 |
Carlo_P
Rep Power: 7 |
October 23, 2019, 11:14 |
#4 | |
Maveryck Andres
Rep Power: 7 |
Epsilon boundary conditions Code:
dimensions [0 2 -3 0 0 0 0]; internalField uniform 0.6; boundaryField { inlet { type cyclic; } outlet { type cyclic; } FixedWalls { type zeroGradient; } } Code:
internalField uniform 0.05; boundaryField { inlet { type cyclic; } outlet { type cyclic; } FixedWalls { type fixedValue; value uniform 1.0e-08; } } Code:
internalField uniform (0.1 0 0); boundaryField { inlet { type cyclic; } outlet { type cyclic; } FixedWalls { type noSlip; } } Code:
momentumSource { type meanVelocityForce; active yes; selectionMode all; fields (U); Ubar (1.9 0 0); } |
blockmesh, cylinder domain, mesh |
[blockMesh] 3-D Mesh in a cylinder | Nikunj.R | OpenFOAM Meshing & Mesh Conversion | 32 | July 9, 2023 13:22 |
[blockMesh] Cylinder mesh using blockMesh with m4 macro | Lewis Liang | OpenFOAM Meshing & Mesh Conversion | 2 | November 21, 2017 02:28 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
rotating cylinder using sliding mesh | Tim Daly | FLUENT | 1 | November 9, 2008 23:02 |
