[snappyHexMesh] Large number of bad cells with sHM |
November 25, 2019, 13:06 |
Jalil
Rep Power: 7 |
Hello all,
I am using compressibleInterFoam solver in OpenFoam to simulate the effects of entrapped air in a water pipeline. But I have problem with generating the Mesh for the simulation. The apparatus is composed of a large tank at the upstream, a 10 m long horizontal pipe with 0.1 m diameter, and a vertical ventilation tower (Diameter=5 cm) that releases the air, the ventilation hole at the top of the tower has an area of 5% of the ventilation tower area (Diameter = 1.135 cm). In order to make a mesh that has all the apparatus, I need to make very fine cells around the ventilation tower and courser mesh (larger cells) everywhere else. Whenever, I run the snappyHexMesh, I get the mesh generated, but the number of bad cells are huge. Therefore, the simulation always crashes. I have attached a screenshot of the final step of running snappyHexMesh. When I set the case and run it, it always crushes. I guess the main reason is the bad cells. I also think that I cannot set the boundary condition properly. Therefore, I have attached a zip folder of the case. Here is the link to the case folder. https://www.dropbox.com/s/9fxvjcsgnezq7h7/Off_campus_Nov.zip?dl=0 I shall be very grateful if someone can help me overcome this issue or introduce any other way of the creating mesh that can work. Thank you all in advance! |
January 27, 2020, 08:22 |
Ben B. Huang
Rep Power: 13 |
Hi Jalil,
If you are looking for CFD modeling of storm geysers, a book chapter may be helpful. https://doi.org/10.1061/9780784415313.ch23. (Chapter 23: Geysering in Computational Fluid Dynamics: Applications in Water, Wastewater, and Stormwater Treatment) Both ANSYS CFX and OpenFOAM were used. The tutorial files can be found in https://doi.org/10.4211/hs.344350caa...a9eb33cbed3f78. Cheers. Biao |
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' | BrendaEM | OpenFOAM Meshing & Mesh Conversion | 12 | April 3, 2022 18:32 |
SimpleFoam & Theater | jipai | OpenFOAM Running, Solving & CFD | 3 | June 18, 2019 10:11 |
decomposePar -allRegions | stru | OpenFOAM Pre-Processing | 2 | August 25, 2015 03:58 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
