December 16, 2019, 14:42 |
Room Leakage
Rep Power: 8 |
I want to simulate air flow from one room to another through a leakage at the wall using openfoam. I would like to know if there is a command for this or do I need to specify the area in the wall where the leakage would happen as a patch in blockMesh.
Thanks |
December 17, 2019, 16:57 |
Herpes Free Engineer
Rep Power: 12 |
I think the second, or toposet.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
Radiation and convection heat transfer in a room through heat pipe | mankaran90 | FLUENT | 0 | February 26, 2018 05:08 |
hydrogen leakage in the room | mamalili | FLUENT | 2 | February 1, 2015 00:13 |
[ICEM] Ogride in of a room in ICEM CFD | metmet | ANSYS Meshing & Geometry | 3 | July 31, 2014 14:00 |
[GAMBIT] Object in room with that object being the purpose of investigation | fluentgambituser | ANSYS Meshing & Geometry | 3 | August 24, 2011 01:52 |
Salome and Code Saturne simulation of simple room and objects | cristian.ocnarescu | Main CFD Forum | 0 | June 21, 2010 10:19 |
