[Salome] Is meshgems (add on module in salome) is good for hexmeshing of fluid domain to be ru
Old   November 28, 2019, 02:15
Default Is meshgems (add on module in salome) is good for hexmeshing of fluid domain to be ru
ijaz fazil
er_ijaz is on a distinguished road
Hi
I'm currently using snappyhex mesh for meshing my fluid domain to run simulation in openfoam.
I found salome is better free alternative to snappyhexmesh, but the time required by the mesh created via salome is more than then mesh created using helyx (snappyhex).
There is a module callled meshgems in salome to be purchased in order to create hex mesh.
Is it worth buying meshgems to create hex mesh for openfoam application?
er_ijaz is offline   Reply With Quote
Old   December 17, 2019, 13:46
Damian Berghof
virengos will become famous soon enough
I've been using both solutions for many years. Both solutions have their pros and cons (snappyHexMesh and Salome). Depends on your reference case (mesh structure, number of cells, boundary layer, required quality, your available time to play around and more). (1) snappy is quite powerful, it's scriptable, running in parallel, and has a great community (2) standard Salome meshing module is running on 1 CPU, but it is very fast for hexa meshing, it's also scriptable with Python, one can use directly the geometry in STEP format. (3) The Distene's MeshGems seems to be really good, but might be useless without additional subscription, support and training (4) I myself would rather spend part of the money to fund the OpenFOAM foundation and to strengthen the community, with the other part of the money you could hire an expert to teach you both software approaches. (5) A other solution might be to look for a mid-price OpenFOAM software for Linux or Windows with a high-quality support.
That's my personal point of view!
best,
Damian
Get more support about Meshing with Salome and Visualization with ParaView in my growing groups
https://bit.ly/2lFfDkQ
https://bit.ly/2k2u8Pj
virengos is offline   Reply With Quote
gmsh, mesh, openfoam, salome, snappyhesmeshdict
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
[DesignModeler] Extracting fluid domain for a compressor supermanks ANSYS Meshing & Geometry 11 June 8, 2015 10:14
injection problem Mark New FLUENT 0 August 4, 2013 01:30
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
