[blockMesh] Curved or wavy geometry
Old   January 2, 2020, 12:38
Default Curved or wavy geometry
Alex
Sedullo is on a distinguished road
Hello everyone,
I need to build a 2d mesh that is basically a vertical rectangle where 3 sides are straight but one (that one on the right) has the shape of a wave (or sine curve).
My idea was to build a lot of blocks with blockmesh, like a puzzle, but I do not know if there is a faster way to generate a sinusoidal shape.
If you have any suggestion or just a comment please help me.
I am quite new in OpenFOAM and I do not know if blockmesh is the right tool for my purpose, in case let me know.
Sedullo is offline   Reply With Quote
Old   January 3, 2020, 04:53
Antimony is on a distinguished road
When you mean 2D, with blockMesh, remember that you will need to have only 1 element in the 3rd direction....
As for creating sine curve, what you can do is to specify a spline between the two vertices in the edges subsection.
For example, you could have something like this:
vertices
    (0 0 0)
    (1 0 0)
    (1 1 0)
    (0 1 0)
    (0 0 1)
    (1 0 1)
    (1 1 1)
    (0 1 1)
blocks
    hex (0 1 2 3 4 5 6 7) (10 10 1) simpleGrading (1 1 1)
edges
    spline 2 1 ((0.8 0.75 0) (1 0.5 0) (1.2 0.25 0))
    spline 6 5 ((0.8 0.75 1) (1 0.5 1) (1.2 0.25 1))
Hope this helps.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   January 6, 2020, 18:43
Alex
Using "spline" I very easily managed to make the sine curve I was looking for, thank you so much!
curve mesh, wavy channel, wavy fins
[ICEM] Holes in complex ICEM geometry alecbann ANSYS Meshing & Geometry 2 April 4, 2019 03:40
[Workbench] Workbench 18.2 SpaceClaim->Mechanical geometry accuracy/tolerance problem sultzan ANSYS Meshing & Geometry 0 December 13, 2018 17:41
[GAMBIT] Meshing problem on a simple curved geometry (Gambit Software) Parham Vatankhah ANSYS Meshing & Geometry 3 February 19, 2018 03:02
Export geometry file from ansys mechanical browns6 Structural Mechanics 0 August 27, 2013 16:19
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
