[mesh manipulation] How to use a volScalarField as cellDisplacement input (dynamic mesh)?
Like Tree1Likes
  • 1 Post By ocean12
Old   May 4, 2022, 14:48
Default How to use a volScalarField as cellDisplacement input (dynamic mesh)?
ocean12 is on a distinguished road
Hello Foamers,
I have been stuck with a problem and I hope you can help me. I would like to use the dynamic mesh feature of OpenFOAM in a specific manner: I have an object of class volScalarField as output of a customized solver, which contains values for ground surface displacement (negative for erosion, positive for growth). I would like to "feed" these values directly as an input for the dynamic mesh motion at each time step for the bottom boundary. I have looked into tutorials such as wingMotion and SnakeRiverCanyon, but none of them corresponded to my specific case.
Is it possible to simply specify a set of values (in a volScalarField) as input for cellDisplacement of a patch, without performing any computations related to the dynamic evolution of the mesh?
I hope my question is clear. Let me know if you need any other details!
Thanks a lot,
Sara
scleakey likes this.
ocean12 is offline   Reply With Quote
Dynamic Mesh on Pintle type injector. herntan FLUENT 16 September 4, 2020 08:27
objects oscillate at high speed causing collapse in Dynamic mesh and overset mesh ca insane OpenFOAM Running, Solving & CFD 0 May 17, 2020 22:35
Dynamic Mesh kennyboy FLUENT 1 February 23, 2019 01:52
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
Local mesh refinement definition in a DEFORMING dynamic mesh zone using Dynamic Mesh Emanuele88 FLUENT 0 February 9, 2016 11:39
