[blockMesh] FOAM FATAL ERROR: Inconsistent number of faces blockMesh::createMergeList() line 193
Old   September 15, 2010, 08:30
Default FOAM FATAL ERROR: Inconsistent number of faces blockMesh::createMergeList() line 193
Franz Hengel
Hengel is on a distinguished road
Hallo!
I have got some troubles with blockMesh:
Here my problem
Code:franz@franz-desktop:~/OpenFOAM/franz-1.7.1/DA_aktuell/2D_FreeConvection/020_FreeConvection_SKE_buoyantSimpleFoam$ blockMesh
| \\ / O peration | Version: 1.7.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
Build : 1.7.1-03e7e056c215
Exec : blockMesh
Date : Sep 15 2010
Time : 13:12:38
Host : franz-desktop
PID : 4753
Case : /home/franz/OpenFOAM/franz-1.7.1/DA_aktuell/2D_FreeConvection/020_FreeConvection_SKE_buoyantSimpleFoam
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Creating block mesh from
"/home/franz/OpenFOAM/franz-1.7.1/DA_aktuell/2D_FreeConvection/020_FreeConvection_SKE_buoyantSimpleFoam/constant/polyMesh/blockMeshDict"
Creating blockCorners
Creating curved edges
Creating blocks
Creating patches
Creating block mesh topology
Default patch type set to empty
Check block mesh topology
Basic statistics
Number of internal faces : 12
Number of boundary faces : 30
Number of defined boundary faces : 30
Number of undefined boundary faces : 0
Checking patch -> block consistency
Creating block offsets
Creating merge list
--> FOAM FATAL ERROR:
Inconsistent number of faces between block pair 0 and 3
From function blockMesh::createMergeList()
in file createMergeList.C at line 193.
FOAM exiting
You can see the blockMeshDict-File below:
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(0 0 0) //Punkt 0
(0.00762 0 0) //Punkt 1
(0.06858 0 0) //Punkt 2
(0.0762 0 0) //Punkt 3
(0 0.00762 0) //Punkt 4
(0.00762 0.00762 0) //Punkt 5
(0.06858 0.00762 0) //Punkt 6
(0.0762 0.00762 0) //Punkt 7
(0 2.17238 0) //Punkt 8
(0.00762 2.17238 0) //Punkt 9
(0.06858 2.17238 0) //Punkt 10
(0.0762 2.17238 0) //Punkt 11
(0 2.18 0) //Punkt 12
(0.00762 2.18 0) //Punkt 13
(0.06858 2.18 0) //Punkt 14
(0.0762 2.18 0) //Punkt 15
(0 0 0.01) //Punkt 16
(0.00762 0 0.01) //Punkt 17
(0.06858 0 0.01) //Punkt 18
(0.0762 0 0.01) //Punkt 19
(0 0.00762 0.01) //Punkt 20
(0.00762 0.00762 0.01) //Punkt 21
(0.06858 0.00762 0.01) //Punkt 22
(0.0762 0.00762 0.01) //Punkt 23
(0 2.17238 0.01) //Punkt 24
(0.00762 2.17238 0.01) //Punkt 25
(0.06858 2.17238 0.01) //Punkt 26
(0.0762 2.17238 0.01) //Punkt 27
(0 2.18 0.01) //Punkt 28
(0.00762 2.18 0.01) //Punkt 29
(0.06858 2.18 0.01) //Punkt 30
(0.0762 2.18 0.01) //Punkt 31
blocks
hex (0 1 5 4 16 17 21 20) (10 1 1) simpleGrading (1 1 1) // Block 0
hex (1 2 6 5 17 18 22 21) (1 1 1) simpleGrading (1 1 1) // Block I
hex (2 3 7 6 18 19 23 22) (1 1 1) simpleGrading (1 1 1) // Block II
hex (4 5 9 8 20 21 25 24) (1 1 1) simpleGrading (1 1 1) // Block III
hex (5 6 10 9 21 22 26 25) (1 1 1) simpleGrading (1 1 1) // Block IV
hex (6 7 11 10 22 23 27 26) (1 1 1) simpleGrading (1 1 1) // Block V
hex (8 9 13 12 24 25 29 28) (1 1 1) simpleGrading (1 1 1) // Block VI
hex (9 10 14 13 25 26 30 29) (1 1 1) simpleGrading (1 1 1) // Block VII
hex (10 11 15 14 26 27 31 30) (1 1 1) simpleGrading (1 1 1) // Block VIII
edges
patches
wall hot
(19 23 7 3)
(23 27 11 7)
(27 31 15 11)
wall cold
(0 16 20 4)
(4 20 24 8)
(8 24 28 12)
wall topAndBottom
(0 1 17 16)
(1 2 18 17)
(2 3 19 18)
(12 28 29 13)
(13 29 30 14)
(14 30 31 15)
empty frontAndBackPlanes
(0 4 5 1)
(1 5 6 2)
(2 6 7 3)
(4 8 9 5)
(5 9 10 6)
(6 10 11 7)
(8 12 13 9)
(9 13 14 10)
(10 14 15 11)
(16 20 21 17)
(17 21 22 18)
(18 22 23 19)
(20 24 25 21)
(21 25 26 22)
(22 26 27 23)
(24 28 29 25)
(25 29 30 26)
(26 30 31 27)
mergePatchPairs
If I replace the values for the meshrefinement from (10 1 1) to (1 1 1), see below, then blockMesh will work
Code: hex (0 1 5 4 16 17 21 20) (1 1 1) simpleGrading (1 1 1) // Block 0
Can anyone help me to solve this problem?
I guess there can be a problem with the block IV coz it is positioned in the middle of the geometry and around there are all other blocks. The block IV does not have any contacts to the walls
Thanks for your support
best regards
Franz
Hengel is offline   Reply With Quote
Old   September 17, 2010, 04:27
marval is on a distinguished road
Hello Franz!
I don't see where the problem is, you seem to have figured it out by yourself!
The change you did had nothing to do with the refinement (grading), it was the number of elements in each direction (x y z).
Regards
Marco
marval is offline   Reply With Quote
Old   September 17, 2010, 05:07
Franz Hengel
Hallo marval!
Thank you for your attention!
I solved the problem.
I think the problem is the amout of cells just in the first block. The neighbor cells requires the same amount of cells. If you do not do this then you will get an error like this:
FOAM exiting
Solution:
I set the some number of cells to the neighbor cells and then it works fine.
Btw., can blockMesh work with hanging nodes?
Thx
best regards
Franz
Old   September 17, 2010, 05:36
FOAM exiting
Solution:
Exactly! You only have one cell in each direction for each block?
I'm not sure what that means, is it a defined point that's not used to construct the geometry?
Regards
Marco
Old   September 17, 2010, 06:01
Franz Hengel
FOAM exiting
Solution:
Yes secondly.
First of all I had 10 cells in the x direction in the first block, so I had to change the upper and the lower neighbor. Both have 10 cells in the x-direction now.
Hanging-node splits e.g. cells into two pieces but do not change the primary size of the cell. You can compare it with fluent at Yplus/Ystar Adaption. Here you can adapt the y+ value with hanging nodes.
Now I think, If the hanging-node-methode is working in OpenFoam the main problem could be the aspect ratio. The max. of aspect ratio is 10:1.
best
Franz
Old   December 30, 2015, 09:42
Satyaki
Ray092 is on a distinguished road
help me with this error please
| \\ / O peration | Version: 2.3.x |
| \\ / A nd | Web: www.OpenFOAM.org |
/* Windows port by CFD support (www.cfdsupport.com) [based on Symscape] *\
Build : 2.3.x-819030ed51bd
Exec : D:\openfoamwindows\OpenFOAM\cygwin64\opt\OpenFOAM\ OpenFOAM-2.3.x\platfo rms\cygwin64mingw-w64DPOpt\bin\blockMesh.exe
Date : Dec 30 2015
Time : 10:26:23
Host : "SATYAKI-PC"
PID : 4004
Case : D:/openfoamwindows/OpenFOAM/cygwin64/home/satyaki/FOAM_RUN/tutorials/mu ltiphase/multiphaseEulerFoam/bubbleColumnMod1
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMas ter
allowSystemOperations : Disallowing user-supplied system call operations
Create time
"D:/openfoamwindows/OpenFOAM/cygwin64/home/satyaki/FOAM_RUN/tutorials/multip hase/multiphaseEulerFoam/bubbleColumnMod1/constant/polyMesh/blockMeshDict"
Creating topology blocks
Creating topology patches
Reading patches section
Reading physicalType from existing boundary file
--> FOAM Warning :
From function polyMesh:: polyMesh(... construct from shapes...)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 903
Found 14 undefined faces in mesh; adding to default patch.
Check topology
Basic statistics
Number of internal faces : 4
Number of boundary faces : 22
Number of defined boundary faces : 22
Creating merge list
Inconsistent number of faces between block pair 0 and 1
From function blockMesh::calcMergeInfo()
in file blockMesh/blockMeshMerge.C at line 221.
FOAM exiting
here's my blockmeshdict file
| \\ / O peration | Version: 2.3.0 |
FoamFile
version 2.0;
format ascii;
class dictionary;
convertToMeters 0.001;
vertices
(0 0 0)
(90 0 0)
(90 200 0)
(0 200 0)
(99 0 0)
(99 200 0)
(101 200 0)
(101 0 0)
(110 0 0)
(110 200 0)
(200 200 0)
(200 0 0)
(0 0 100)
(90 0 100)
(90 200 100)
(0 200 100)
(99 0 100)
(99 200 100)
(101 200 100)
(101 0 100)
(110 0 100)
(110 200 100)
(200 200 100)
(200 0 100)
blocks
hex (0 1 2 3 12 13 14 15) (10 200 1) simpleGrading (1 1 1)
hex (2 1 4 5 14 13 16 17) (10 200 1) simplegrading (1 1 1)
hex (5 4 7 6 17 16 19 18) (10 200 1) simplegrading (1 1 1)
hex (6 7 8 9 18 19 20 21) (10 200 1) simplegrading (1 1 1)
hex (9 8 11 10 21 20 23 22) (10 200 1) simplegrading (1 1 1)
edges
patches
patch inlet
(4 16 19 7)
patch outlet
(3 15 14 2)
(2 14 17 5)
(5 17 18 6)
(6 18 21 9)
(9 21 22 10)
wall walls
(0 12 15 3)
(11 23 22 10)
mergePatchPairs
Ray092 is offline   Reply With Quote
Old   December 30, 2015, 21:21
Maryam
Persia is on a distinguished road
The first block should be defined like this to be consistent with the other blocks:
hex (3 0 1 2 15 12 13 14) (10 200 1) simpleGrading (1 1 1)
Persia is offline   Reply With Quote
Old   November 15, 2021, 22:56
Default --> FOAM FATAL ERROR: Inconsistent number of faces between block pair 0 and 3 Fr
SURENDAR KUMAR V
SURENDAR KUMAR V is on a distinguished road
This is an axisymmetric problem.Please help me with the error.
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 7
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class dictionary;
vertices
(0 0 0) (3.496668776 0 0.152667855) (4.995241108 0 0.218096936) (47.45479053 0 2.0719209)
(0 35 0) (3.496668776 35 0.152667855) (4.995241108 35 0.218096936) (47.45479053 35 2.0719209)
(0 200 0) (3.496668776 200 0.152667855) (4.995241108 200 0.218096936) (47.45479053 200 2.0719209)
(3.496668776 0 -0.152667855) (4.995241108 0 -0.218096936) (47.45479053 0 -2.0719209)
(3.496668776 35 -0.152667855) (4.995241108 35 -0.218096936) (47.45479053 35 -2.0719209)
(3.496668776 200 -0.152667855) (4.995241108 200 -0.218096936) (47.45479053 200 -2.0719209)
blocks
hex (0 1 12 0 4 5 15 4) gas (7 70 1) simpleGrading (1 1 1)
hex (1 2 13 12 5 6 16 15) solid ( 3 70 1) simpleGrading (1 1 1)
hex (2 3 14 13 6 7 17 16) gas (85 70 1) simpleGrading (1 1 1)
hex (4 5 15 4 8 9 18 8) gas (7 330 1) simpleGrading (1 1 1)
hex (5 6 16 15 9 10 19 18) gas ( 3 330 1) simpleGrading (1 1 1)
hex (6 7 17 16 10 11 20 19) gas (85 330 1) simpleGrading (1 1 1)
edges
boundary
inletFuel
type patch;
faces
(0 12 1 0)
inletAir
type patch;
faces
(13 14 3 2)
outlet
type patch;
faces
(8 9 18 8)
(9 10 19 18)
(10 11 20 19)
(20 11 7 17)
external
type patch;
faces
(12 13 2 1)
wall
type wall;
faces
(17 7 3 14)
wedgeNeg
type wedge;
faces
(4 15 12 0)
(15 16 13 12)
(16 17 14 13)
(8 18 15 4)
(18 19 16 15)
(19 20 17 16)
wedgePos
type wedge;
faces
(0 1 5 4)
(1 2 6 5)
(2 3 7 6)
(4 5 9 8)
(5 6 10 9)
(6 7 11 10)
axis
type empty;
faces
(0 4 4 0)
(4 8 8 4)
mergePatchPairs
\\/ M anipulation |
Build : 7-63349425784a
Exec : blockMesh
Date : Nov 13 2021
Time : 07:04:19
Host : "tdce115"
PID : 3846
I/O : uncollated
Case : /home/praise/sktutorial/Burner_MRF
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
"/home/praise/sktutorial/Burner_MRF/system/blockMeshDict"
Creating block edges
No non-planar block faces defined
Check topology
Basic statistics
Number of internal faces : 7
Creating merge list
From function void Foam::blockMesh::calcMergeInfo()
in file blockMesh/blockMeshMerge.C at line 222.
FOAM exiting
SURENDAR KUMAR V is offline   Reply With Quote
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 09:23
[snappyHexMesh] SHM Layer Addition Phase dickcruz OpenFOAM Meshing & Mesh Conversion 4 November 1, 2018 07:05
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) AndreP STAR-CCM+ 10 August 2, 2018 07:48
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 13:38
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
