[snappyHexMesh] How to create cyclic non-matching patches?
Old   March 16, 2020, 06:24
Default How to create cyclic non-matching patches?
Tobias Kienzler
zommuter is on a distinguished road
I'd like to mesh part of periodic tube with cyclic patches, i.e. while the internal structure is irregular and provided by an OBJ file, the cyclic patches are identical but rotated. Just using a naive run on snappyHexMesh and createPatches
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      createPatchDict;
pointSync false;
// Patches to create.
patches
        name cyclAMI.Front;
        patchInfo
            type cyclicAMI;
            neighbourPatch cyclAMI.Back;
            // Optional: explicitly set transformation tensor.
            // Used when matching and synchronising points.
            transform rotational;
            rotationAxis (0 0 1);
            rotationCentre (0 0 0);
        constructFrom patches;
        patches (Front);
        name cyclAMI.Back;
        patchInfo
            type cyclicAMI;
            neighbourPatch cyclAMI.Front;
            rotationAxis    ( 0 0 1 );
            rotationCentre  ( 0 0 0 );
        patches (Back);
I cannot use cyclic but must use cyclicAMI due to the mismatch of the Front and Back patch meshing. But then I obtain zero weights in the AMIs, and due to the actually (but rotated) identical faces I'd prefer to use a real cyclic non-AMI boundary condition anyway. Is there any way to achieve this? I guess I'd need to instruct snappyHexMesh somehow to create the patches identically if that is somehow possible.
Cheers
zommuter is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[snappyHexMesh] snappyHexMesh and cyclic boundaries Ruli OpenFOAM Meshing & Mesh Conversion 2 December 9, 2013 06:51
Cyclic boundaries in OF 21x morard OpenFOAM 25 May 13, 2013 22:35
[mesh manipulation] CreatePatch to create cyclic boundary sbence OpenFOAM Meshing & Mesh Conversion 18 August 30, 2012 06:51
[snappyHexMesh] snappyHexMesh with cyclic patches? Axel_T OpenFOAM Meshing & Mesh Conversion 1 October 12, 2010 10:03
