[Commercial meshers] "can not find faces using edges.."when using the ICEM mesh |
March 17, 2020, 11:11 |
bany
Rep Power: 7 |
My mesh is built by ICEM with hanging nodes when using the refinement in ICEM. And when i convert it into OpenFOAM by fluent3dmeshtofoam with checkMesh being OK, the case can be calculated. But when i use the functionObjects which involves meshTool.C in controlDict, the error "can not find faces using edges.." comes.
More in detail, my domain is a cylinder. And i use the O-block to build the structured mesh in ICEM. To refine certain block, i use the refinement tool, which cause the hanging nodes and uncovered faces. But when i convert it into OpenFOAM using fluent3dmeshtofoam, the mesh is Ok as i check the mesh. So i think the fluent3dmeshtofoam can merge these hanging nodes, just like FLUENT which can deal with the 1=>2 ratio refinement. But when i run the case, i find the errors "can not find faces using edges..". Finally, i find the errors come from meshTool.C because i use the functionObjects which involves meshTool.C in controlDict. You can find more detail in uncovered faces after refinement in 3D which is posted by me. |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
