[Commercial meshers] Star CCM+ mesh to .msh format for use in Fluent
Like Tree4Likes
  • 3 Post By Shubham_SD
  • 1 Post By miragemobile
Old   May 26, 2016, 15:06
Default Star CCM+ mesh to .msh format for use in Fluent
Shubham Deshmukh
Shubham_SD is on a distinguished road
I am trying to convert .ccm mesh to fluent readable format .msh through OpenFOAM v3.0+ . I am completely new to OpenFOAM and using it on Windows 8.1 using Docker tool. Can anyone please help me to perform the mesh conversion?
Would be really thankful!
Shubham
Shubham_SD is offline   Reply With Quote
Old   May 31, 2016, 10:31
Stefano Gaggero
Mashiro5 is on a distinguished road
Dear Shubham,
you have to install an optional plugin (ccm26ToFoam) in order to be able to convert meshes from ccm+ to OpenFOAM format.
Here in the forum you can find some dedicated pages that explain how to obtain this plugin and install it. Also openfoamwiki is useful.
Good luck,
Stefano
Mashiro5 is offline   Reply With Quote
Old   June 1, 2016, 16:00
Default Star CCM+ mesh Imported into Fluent
Shubham Deshmukh
Thanks Stefano!
Well I actually got a better option than using OPENFOAM, directly convert the star ccm+ mesh (I used in 3D) into Tecplot 360 (.plt) format which is readable in Fluent solver.
For future reference:
In Star CCM+, Export > Mesh Only (Select all boundaries and regions) > save in Tecplot 360 (.plt).
In ANSYS Workbench, Component Systems (Left pane) > Fluent > Setup > (opens Fluent solver) > File >Import > Tecplot...!!!
Shubham
Old   April 9, 2020, 08:40
miragemobile is on a distinguished road
Originally Posted by Shubham_SD View Post
Thanks Stefano!
Shubham
Is there a known size limitation for exporting meshes in the *.plt format? I was able to export a 120E+06 cell mesh but starccm+ fails to export a 220E+06 cell mesh.
Also, does FLUENT have a known size limiting for importing meshes? I was able to export from STARCCM to *.case with the 220E+06 cell mesh, but FLUENT has been importing the file for 48 hours.
bikooo3878 likes this.
miragemobile is offline   Reply With Quote
[ANSYS Meshing] Export mesh ( .msh) in a ASCII format pedroxramos ANSYS Meshing & Geometry 14 June 20, 2020 12:30
Can fluent tet mesh be converted into Polyhedral mesh in CCM? jealor STAR-CCM+ 7 January 10, 2018 05:25
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
How to convert STAR mesh into FLUENT mesh ? Jihwan Siemens 8 November 10, 2004 04:11
Convert FLUENT mesh to some other format for STAR? Jiaying Xu FLUENT 3 December 5, 2002 08:15
