[blockMesh] wedge of annular channel
Like Tree1Likes
  • 1 Post By dplamp
Old   August 19, 2020, 04:02
Default wedge of annular channel
dplamp is on a distinguished road
I successfully made a wedge for a cylindrical channel (tube). Now, I'm trying to make one for an annular channel.
By annular channel I mean a tube with a rod along the center line, so the air flows between the rod and the tube wall. The geometry is axis-symmetric.
PROBLEM
I set up the following blockMeshDict, but I get this error :
--> FOAM FATAL ERROR:
face 0 in patch 6 does not have neighbour cell face: 4(0 4 4 0)
Patch 6 is the "axis" patch. Vertices 0 and 4 are supposed to define the axis of symmetry.
Any idea ?
|  \\    /   O peration     | Version:  plus                                  |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
//convertToMeters 0.001;    // mm
convertToMeters 1;        // m
radiusInt    5.5e-3;
radiusExt    8.5e-3;
length    80e-3;
halfWedgeAngle    2.5;    // degrees
// wedge coordinates :
//hAR        #calc "$halfWedgeAngle*Foam::constant::mathematical::pi/180.0";    // half angle in rad
hAR        #calc "degToRad($halfWedgeAngle)";    // half angle in rad
wIx        #calc "$radiusInt*cos($hAR)";       // internal wall x
wIyp    #calc "$radiusInt*sin($hAR)";       // internal wall y pos
wIyn    #calc "-1.0*$wIyp";                 // internal wall y neg
wEx        #calc "$radiusExt*cos($hAR)";       // external wall x
wEyp    #calc "$radiusExt*sin($hAR)";       // external wall y pos
wEyn    #calc "-1.0*$wEyp";                 // external wall y neg
cs        #calc "cos($hAR)";                  // cosine of the half angle
//#calc "Info<< $halfWedgeAngle << $cs << $wIx << $wIyp << $wIyn";
//#calc "Info<< $halfWedgeAngle << $cs << $wEx << $wEyp << $wEyn";
vertices
    (0 0 0) // 0
    (1 0 0)
    (0 1 0)
    (0 0 1)
    (0 0 $length)   // 4
    ($wIx $wIyp 0)    // 5
    ($wIx $wIyn 0)
    ($wEx $wEyn 0)
    ($wEx $wEyp 0)
    ($wIx $wIyp $length)    // 9
    ($wIx $wIyn $length)
    ($wEx $wEyn $length)
    ($wEx $wEyp $length)
blocks
    hex (5 6 7 8 9 10 11 12) (50 1 200) simpleGrading (0.5 1 1)
edges
boundary
    inlet
        type patch;
        faces
            (8 7 6 5)
    outlet
        type patch;
        faces
            (9 10 11 12)
    wallPipeInt
        type wall;
        faces
            (5 6 10 9)
    wallPipeExt
        type wall;
        faces
            (8 12 11 7)
    front
        type wedge;
        faces
            (6 7 11 10)
    back
        type wedge;
        faces
            (5 9 12 8)
    axis
        type symmetry;
        faces
            (0 4 4 0)
mergePatchPairs
dplamp is offline   Reply With Quote
Old   August 20, 2020, 07:56
anonymous
simrego is on a distinguished road
Hi!
You don't have anything at the "axis". There is no mesh. You don't even need this patch.
You have only one block of mesh defined by the (5 6 7 8 9 10 11 12) vertices.
In this case you don't need the axis patch since you don't have mesh there. Just remove the axis entry from the boundary definition and you are done.
simrego is offline   Reply With Quote
Old   August 21, 2020, 03:29
Default [SOLVED] wedge of annular channel
Removing the axis did it, thanks ! I'm posting the new setup, should it be helpful to anyone.
I had to reorganize the vertices a little bit. I added some finer cell grading close to the walls too.
blockMeshDict :
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
radiusInt    5.5e-3;
radiusExt    8.5e-3;
length    80e-3;
vertices
    (0 0 0) // 0
    (1 0 0)
    (0 1 0)
    (0 0 1)
    ($wIx $wIyn 0)           // 4
    ($wEx $wEyn 0)
    ($wIx $wIyp 0)          // 8
    ($wEx $wEyp 0)
blocks
    hex (4 7 11 8 5 6 10 9) (50 1 200)
    simpleGrading
            (0.2 0.3 4)     // 20% x-dir, 30% cells, expansion = 4
            (0.6 0.4 1)     // 60% x-dir, 40% cells, expansion = 1
            (0.2 0.3 0.25)  // 20% x-dir, 30% cells, expansion = 0.25 (1/4)
        1                   // y-direction expansion ratio
        1                   // z-direction expansion ratio
edges
boundary
    inlet
        type patch;
        faces
            (4 8 11 7)
    outlet
        type patch;
        faces
            (5 6 10 9)
    wallPipeInt
        type wall;
        faces
            (4 5 9 8)
    wallPipeExt
        type wall;
        faces
            (11 10 6 7)
    front
        type wedge;
        faces
            (7 6 5 4)
    back
        type wedge;
        faces
            (8 9 10 11)
mergePatchPairs
Nomis likes this.
[Other] Wedge patch '*' is not planar LilumDaru OpenFOAM Meshing & Mesh Conversion 6 January 12, 2021 05:55
Inaccurate results for some turbulent annular flows using K-Omega SST donree4 OpenFOAM Running, Solving & CFD 1 March 19, 2019 18:15
Axisymmetric Whirl BCs; Wedge or Cyclic? c_dowd OpenFOAM Pre-Processing 4 December 5, 2012 10:38
Wedge and morpher Henry Arrigo STAR-CCM+ 5 July 6, 2012 18:34
Wall boundary is ignored when using wedge Wedge OpenFOAM 1 February 7, 2011 06:20
