[mesh manipulation] Creating cellSets bases on existing regions |
September 22, 2020, 03:55 |
Rep Power: 8 |
Hello everyone
I've already found a lot of information regarding the creation of regions, cellSets and cellZones. However I haven't found a nice solution for my problem. In an automated workflow I use mergeMeshes to merge multiple meshes together. The goal is to have a cellZone for each mesh that got merged. The mergeMeshes utility will merge the meshes and create a region (region0, region1, ...) for each of the merged meshes. The simplest way I've found to convert the regions into cellZones is the following: Code:
splitMeshRegions -makeCellZones -overwrite A prefered way would be the following:
The second point is no problem, the first point seems to be more tricky. If I run checkMesh, this will be done and the cellSets are named region0, region1, ... but running checkMesh at this point is a waste of time in this workflow. I also took a look at setSet, but couldn't find a command that uses regions. How can I create cellSets for each existing region? Thank you in advance, regards nope |
November 16, 2023, 09:03 |
Shenhui Ruan
Rep Power: 4 |
Hi nope,
maybe the reply is very delayed. But I think you can create stl files for each mesh and then use HTML Code:
searchableSurfaceToCell HTML Code:
setToCellZone Also, I have written a code that can merge multiple meshes simultaneously. I have tested it, and it works very quickly and efficiently even for more than ten thousand meshes. Here is the link. But I didn't put a test case inside, and maybe I will add it later. Anyone who needs it can contact me. I hope it will be useful for others with the same needs. best! |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
Creating new boundary conditions from existing ones | rassilon | OpenFOAM Running, Solving & CFD | 0 | February 12, 2010 02:43 |
Creating new mesh from existing mesh | az_f | ANSYS Meshing & Geometry | 5 | January 18, 2010 23:12 |
Problems with Meshing: Collapsed Cells | Emmanuel Resch | Siemens | 1 | July 30, 2007 03:02 |
creating spline along existing line cell? | guang ai | Siemens | 3 | September 4, 2006 02:33 |
