September 24, 2020, 11:55 |
CyclicAMI boundaries Issues
Marco Sala
Rep Power: 6 |
Hello everyone, i'm a beginner in CFD and in OpenFoam in general. I want build a cylinder using CyclicAMI boundaries fot the inlet e for the outlet. I set up the blockMeshDict in this way:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; //- Half angle of wedge in degrees halfAngle 2.5; //- Radius of pipe [m] radius 0.5; radHalfAngle #calc "degToRad($halfAngle)"; x #calc "$radius*sin($radHalfAngle)"; x_ #calc "-1.0*$x"; y #calc "$radius*cos($radHalfAngle)"; //-Pipe lengt L 15; vertices ( (0.0 0.0 0) //0 (0.0 0.0 $L) (0.0 0.0 $L) //2 (0.0 0.0 0) ($x_ $y 0) //4 ($x_ $y $L) ($x $y $L) //6 ($x $y 0) ); blocks ( // cyc_inlet block hex (0 3 7 4 1 2 6 5) (1 80 10) simpleGrading (1 0.4 1) ); edges ( arc 4 7 (0 $radius 0) arc 5 6 (0 $radius $L) ); boundary ( cyc_inlet { type cyclicAMI; neighbourPatch cyc_outlet; faces ( (0 4 7 3) ); transform translational; separationVector (0 0 15); // matchTolerance 300; } cyc_outlet { type cyclicAMI; neighbourPatch cyc_inlet; faces ( (1 2 6 5) ); transform translational; separationVector (0 0 -15); // matchTolerance 300; } side1 { type wedge; faces ( (0 1 5 4) ); } side2 { type wedge; faces ( (7 6 2 3) ); } walls { type wall; faces ( (4 5 6 7) // (3 2 1 0) ); } centerLine { type empty; faces ( (3 2 1 0) ); } ); // ************************************************** *********************** // Running blockMesh I have the error: --> FOAM FATAL ERROR: The distance between the centre of patch cyc_inlet and the transformed centre of patch cyc_outlet is 30. This is greater than the match tolerance of 1.04377e-05 for the patch. Check that the patches are geometrically similar and that any transformations defined between them are correct It might be possible to fix this problem by increasing the "matchTolerance" setting for this patch in the boundary I set matchTolerance as 300 to resolve the error, and in this way I can compute the mesh, but when I'm tray to use decomposePar I obtain: [AMI: Creating addressing and weights between 80 source faces and 80 target faces --> FOAM Warning : From function void Foam::AMIMethod::checkPatches() const in file AMIInterpolation/AMIInterpolation/AMIMethod/AMIMethod/AMIMethod.C at line 65 Source and target patch bounding boxes are not similar source box span : (0.0436194 0.499524 0) target box span : (0.0436194 0.499524 0) source box : (-0.0218097 0 0) (0.0218097 0.499524 0) target box : (-0.0218097 0 30) (0.0218097 0.499524 30) inflated target box : (-0.0468809 -0.0250712 29.9749) (0.0468809 0.524595 30.0251) --> FOAM FATAL ERROR: Unable to find initial target face From function bool Foam::AMIMethod::initialise(Foam::labelListList&, Foam::scalarListList&, Foam::labelListList&, Foam::scalarListList&, Foam::label&, Foam::label&) in file AMIInterpolation/AMIInterpolation/AMIMethod/AMIMethod/AMIMethod.C at line 134. FOAM aborting I'm sure that with OpenFoam4.x version the first solution works, I'm using OpenFoam8, it's a problem of syntax? |
February 11, 2022, 02:37 |
Emeline Noel
Rep Power: 12 |
I have the same issue, do you find what we did wrong? |
February 11, 2022, 03:02 |
SeparationVector in OF1712 and OF9
Emeline Noel
Rep Power: 12 |
With OF1712 the SeparationVector should be given from the patch to the neighbourPatch (for example minY patch to maxY neighbourPatch (0 51. 0.)). But for the OF9, the distance should be given form the neighbourgPatch to the patch, so here (0 -51 0). The exact same blockMeshDict and 0/ folder from OF1712 give the error in OF9: The distance between the centre of patch minY and the transformed centre of patch maxY is 102. The error vanish is the distance is given from the opposite reference. |
February 11, 2022, 03:05 |
Emeline Noel
Rep Power: 12 |
In addition,
It's properly working in parallel on serial with the above suggestion. |
Setting cyclicAMI Boundary conditions | NARENDRAN | OpenFOAM | 0 | July 8, 2020 10:14 |
Getting started with CyclicAMI | Algebraist | OpenFOAM | 4 | February 11, 2019 01:39 |
Setting cyclicAMI and cyclic Boundary conditions (ICEM Mesh to OpenFoam) | bowen1024 | OpenFOAM Pre-Processing | 4 | March 1, 2018 19:28 |
cyclicAMI issue for infinitely long circular cylinder | doctorWho | OpenFOAM Running, Solving & CFD | 1 | July 17, 2017 08:23 |
CyclicAMI with half cylinder/ Projection of boundaries | OlliWer | OpenFOAM Pre-Processing | 0 | December 10, 2013 09:34 |
