[blockMesh] Multiple boundary conditions in one block
Like Tree2Likes
  • 1 Post By Marpole
  • 1 Post By linnemann
Old   June 18, 2013, 05:54
Smile Multiple boundary conditions in one block
EOC
EOC is on a distinguished road
Hi everyone!
I am new to OpenFOAM and also I just started using this platform. My question is that I want to use just one block with six faces, (a cube). So if I want to put a boundary condition to a face such that the boundary condition applies at certain region of the face and not all over it. For example if I want some Heat flux at the centre of a face in a circular region. Do I need to create blocks and faces whenever I need to put a boundary condition ?
Simply putting , I want to know how can I put multiple boundary conditions at the same face such that certain regions of the face have different boundary conditions and certain regions have other boundary conditions.
I will be very thankful for the help
EOC is offline   Reply With Quote
Old   June 18, 2013, 09:14
colinB is on a distinguished road
Hi EOC,
the utility you are looking for is named
setFields
With a setFieldsDict stored in the system folder you can specify
the patch/Region which you want to be changed.
The damBreak tutorial gives you an example of the usage
with a region in the domain specified other than its surroundings
by using the parameter alpha1 which is needed for
multiphase flow.
However this should also work with patches according to the manual
and other fields than alpha1.
I hope that helps
regards
colinB is offline   Reply With Quote
Old   June 19, 2013, 14:45
Smile setFields
EOC
Thank you so much for the help.
I started learning how to use setFields.
Just one more thing. Which option should I use (from boxtocell to surfacetoface)
The condition is I have a wall and some portion of it is heated. The heated portion can be defined by some co-ordinates and it will be a closed surface.
I would have used boxtocell but it only performs the function for a square shaped heated region in my case.
I shall be very thankful for the help.
Old   June 21, 2013, 06:12
Hi
I have no idea how it works in particular with
faces, since I only use the boxToCell option
for my cases and just read in the description
that it is also possible to use this tool for faces as well.
But using some common sense I would say
boxToFace is your option. To figure out how it works
you might want to have a look
here:
/opt/openfoam220/application/utilities/preProcessing/setFields
this is all I know about it
regards
Old   July 10, 2013, 05:22
Artur's Avatar
Artur
Artur will become famous soon enough
Check the wigley hull tutorial in multiphase/LTSInterFoam where the inlet patch has a calculated BC and some of it is set as water (alpha1 field = 1) and some of it as air (alpha1 filed = 0).
I think it should work the same way for you judging from the description you've given.
Artur is offline   Reply With Quote
Old   July 15, 2013, 10:36
benarab
didamiamia is on a distinguished road
hi,
can some one tell me where i have do an error in this blockMesh
| \\ / O peration | Version: 2.2.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(-1 -1 0)
(1 -1 0)
(1 1 0)
(-1 1 0)
(-1 -1 0.1)
(1 -1 0.1)
(1 1 0.1)
(-1 1 0.1)
(0.4 -0.1 0)
(0.6 -0.1 0)
(0.6 0.1 0)
(0.4 0.1 0)
(0.4 -0.1 0.1)
(0.6 -0.1 0.1)
(0.6 0.1 0.1)
(0.4 0.1 0.1)
(-1 -0.1 0)
(1 -0.1 0)
(1 0.1 0)
(-1 0.1 0)
(-1 -0.1 0.1)
(1 -0.1 0.1)
(1 0.1 0.1)
(-1 0.1 0.1)
//add
(0.4 -1 0)
(0.6 -1 0)
(0.6 1 0)
(0.4 1 0)
(0.4 -1 0.1)
(0.6 -1 0.1)
(0.6 1 0.1)
(0.4 1 0.1)
blocks
// hex (0 1 2 3 4 5 6 7) (100 100 1) simpleGrading (1 1 1)
hex (0 24 8 16 4 28 12 20) (50 50 1) simpleGrading (1 1 1)
hex (24 25 9 8 28 29 13 12) (20 30 1) simpleGrading (1 1 1)
hex (25 1 17 9 29 5 21 13) (15 30 1) simpleGrading (1 1 1)
hex (16 8 11 19 20 12 15 23) (70 20 1) simpleGrading (1 1 1)
hex (9 17 18 10 13 21 22 14) (20 20 1) simpleGrading (1 1 1)
hex (19 11 27 3 23 15 31 7) (50 50 1) simpleGrading (1 1 1)
hex (11 10 26 27 15 14 30 31) (20 30 1) simpleGrading (1 1 1)
hex (10 18 2 26 14 22 6 30) (15 30 1) simpleGrading (1 1 1)
edges
boundary
innerwall
type wall;
faces
(11 15 12 8)
(10 14 13 9)
//(11 10 14 15)
(11 15 14 10)
(8 12 13 9)
outerwall
type wall;
faces
(3 7 23 19)
(19 23 20 16)
(16 20 4 0)
(2 6 22 18)
(18 22 21 17)
(17 21 5 1)
(0 4 28 24)
(24 28 29 25)
(25 29 5 1)
(3 7 31 27)
(27 31 30 26)
(26 30 6 2)
frontAndBack
type empty;
faces
(0 24 8 16)
(24 25 9 8)
(25 1 17 9)
(16 8 11 19)
(9 17 18 10)
(19 11 27 3)
(11 10 26 27)
(10 18 2 26)
(4 28 12 20)
(28 29 13 12)
(29 5 21 13)
(20 12 15 23)
(13 21 22 14)
(23 15 31 7)
(15 14 30 31)
(14 22 6 30)
//(0 3 2 1)
//(4 5 6 7)
mergePatchPairs
i have this error :
Create time
Creating block mesh from
"/home/linda/Simulations/caseFI/partie_11/Noconforming_Mesh/P11_move_SRFP/constant/polyMesh/blockMeshDict"
Creating curved edges
Creating topology blocks
Creating topology patches
Creating block mesh topology
Check topology
Basic statistics
Number of internal faces : 8
Number of boundary faces : 32
Number of defined boundary faces : 32
Number of undefined boundary faces : 0
Checking patch -> block consistency
Creating block offsets
Creating merge list
--> FOAM FATAL ERROR:
Inconsistent number of faces between block pair 0 and 1
From function blockMesh::calcMergeInfo()
in file blockMesh/blockMeshMerge.C at line 221.
thank you for answers
didamiamia is offline   Reply With Quote
Old   July 20, 2013, 05:42
Yosmcer Mocktai
Yosmcer will become famous soon enough
I think you should have posted a new thread. I do not see the ling between your error and the usage of setFields.
Your error says there is a problem between your two first blocks:
You defined 50 meshing blocks in y direction for the first block, and 30 for the second one.
This mean that blockMesh cannot connect perfectly theses blocks.
Yosmcer is offline   Reply With Quote
Old   July 22, 2013, 12:18
benarab
you're right I'll post again a new thread for a new topic
thank you for your answer.
Old   October 30, 2020, 08:23
Question
Rosivaldo
chymalaia is on a distinguished road
Has anyone found a solution for this? I have a similar problem, where only a portion of one of my patches should be introducing water into the flow, whereas the surface above introduces another liquid (I'm using interFoam).
Thanks in advance!
chymalaia is offline   Reply With Quote
Old   November 1, 2020, 09:25
RGS
Rohit George Sebastian
RGS is on a distinguished road
Thanks in advance!
Are you trying to simulate 3 phases? Two liquids and air? interFoam (as far as I am aware) only supports two phases. The parts of the geometry that are not filled with one phase is assumed to be filled with the other phase. Of course, a cell can have both phases, and alpha shows what proportion of the cell is filled with each phase.
RGS is offline   Reply With Quote
Old   November 1, 2020, 23:22
Default set boundary condition on partial area of a face
  #11
Charles
Marpole is on a distinguished road
OpenFOAM sets one boundary condition for one patch. On one patch, one can not specify two boundary conditions.
In the case of the cube example, the face needs to be split to 2 in order to accept two boundary conditions. This can be done with a combination of topoSet and createPatch.
In the first step, one need to use topoSet to create faceZone. In topoSetDict, shape of the patch, i.e. circular or rectangular, needs to be defined. Likely one need to create a cellZone first, and then faceZone.
In the second step, using command createPatch to create patches from the faceZone.
With the patches created, to set boundary condition is the same as one did for openFOAM in 0 folder.
setFields can work for some cases. Though it can not change boundary type but only with boundary value. For example, it cannot work if part of the cube face is wall and the rest is inlet. But a combination of topoSet and createPatch can make it.
chymalaia likes this.
Charles L.
Marpole is offline   Reply With Quote
Old   November 2, 2020, 18:54
Thumbs up
  #12
Rosivaldo
Thanks for your answer! Very well explained.
Rosivaldo
Old   November 2, 2020, 18:58
Rosivaldo
No, only 2 phases (2 liquids). The problem was that one of the geometry boundaries had 2 different conditions, and i did not know how to divide the path. But our friend Marpole explained a good way out.
Old   November 3, 2020, 01:26
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
This method also works.
Splitting the Boundaries
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 18:02
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 05:15
Velocity vector in impeller passage ngoc_tran_bao CFX 24 May 3, 2016 21:16
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 17:30
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
