Hi everybody,
I'm having problems with ccmToFoam installation.
I have downloaded the Libccmio-2.6.1.folder (85MB), put it in the thirdparty folder and followed this instructions:
cd $WM_THIRD_PARTY_DIR
./makeCCMIO libso
./makeCCMIO lib
foam
./Allwmake
Afterwards, for the legacy converter (if you need it):
app
cd utilities/mesh/conversion/ccm
./Allwmake
but at last step I have still the same error;
==> skip optional ccm conversion components (no libccm.so)
PLS can somebody helps me? this work is for my thesis.
when I use the first command in Thirdparty folder:
cpMakeFiles libccmio .
wmake lib (libccmio-2.6.1)
Making dependency list for source file ccmioversion.c
Making dependency list for source file ccmioutility.c
Making dependency list for source file ccmiocore.c
Making dependency list for source file ccmioprivate.c
Making dependency list for source file ccmio.c
Making dependency list for source file ADF_internals.c
Making dependency list for source file ADF_interface.c
Making dependency list for source file ADF_fortran_2_c.c
gcc -m64 -DOPENFOAM_PLUS=1706 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -O3 -IlnInclude -I. -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OpenFOAM/lnInclude -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OSspecific/POSIX/lnInclude -fPIC -c libadf/ADF_fortran_2_c.c -o Make/linux64GccDPInt32Opt/libadf/ADF_fortran_2_c.o
gcc -m64 -DOPENFOAM_PLUS=1706 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -O3 -IlnInclude -I. -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OpenFOAM/lnInclude -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OSspecific/POSIX/lnInclude -fPIC -c libadf/ADF_interface.c -o Make/linux64GccDPInt32Opt/libadf/ADF_interface.o
gcc -m64 -DOPENFOAM_PLUS=1706 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -O3 -IlnInclude -I. -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OpenFOAM/lnInclude -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OSspecific/POSIX/lnInclude -fPIC -c libadf/ADF_internals.c -o Make/linux64GccDPInt32Opt/libadf/ADF_internals.o
gcc -m64 -DOPENFOAM_PLUS=1706 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -O3 -IlnInclude -I. -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OpenFOAM/lnInclude -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OSspecific/POSIX/lnInclude -fPIC -c libccmio/ccmio.c -o Make/linux64GccDPInt32Opt/libccmio/ccmio.o
libccmio/ccmio.c: In function ‘MakeEntityName’:
libccmio/ccmio.c:523:40: warning: format not a string literal and no format arguments [-Wformat-security]
snprintf(name, kCCMIOMaxStringLength, gEntityNames[(int)type]);
libadf/ADF_internals.c: In function ‘DC_flush_range’:
libadf/ADF_internals.c:696:29: warning: variable ‘prev’ set but not used [-Wunused-but-set-variable]
struct DISK_CACHE_NODE *prev, *node = disk_cache;
gcc -m64 -DOPENFOAM_PLUS=1706 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -O3 -IlnInclude -I. -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OpenFOAM/lnInclude -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OSspecific/POSIX/lnInclude -fPIC -c libccmio/ccmiocore.c -o Make/linux64GccDPInt32Opt/libccmio/ccmiocore.o
gcc -m64 -DOPENFOAM_PLUS=1706 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -O3 -IlnInclude -I. -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OpenFOAM/lnInclude -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OSspecific/POSIX/lnInclude -fPIC -c libccmio/ccmioprivate.c -o Make/linux64GccDPInt32Opt/libccmio/ccmioprivate.o
gcc -m64 -DOPENFOAM_PLUS=1706 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -O3 -IlnInclude -I. -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OpenFOAM/lnInclude -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OSspecific/POSIX/lnInclude -fPIC -c libccmio/ccmioutility.c -o Make/linux64GccDPInt32Opt/libccmio/ccmioutility.o
libccmio/ccmioutility.c: In function ‘CCMIOCopyNode’:
libccmio/ccmioutility.c:302:6: warning: attempt to free a non-heap object ‘dims’ [-Wfree-nonheap-object]
free(dims);
gcc -m64 -DOPENFOAM_PLUS=1706 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -O3 -IlnInclude -I. -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OpenFOAM/lnInclude -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OSspecific/POSIX/lnInclude -fPIC -c libccmio/ccmioversion.c -o Make/linux64GccDPInt32Opt/libccmio/ccmioversion.o
ar cr /opt/openfoam/v1706/OpenFOAM-v1706/platforms/linux64GccDPInt32Opt/lib/libccmio.a Make/linux64GccDPInt32Opt/libadf/ADF_fortran_2_c.o Make/linux64GccDPInt32Opt/libadf/ADF_interface.o Make/linux64GccDPInt32Opt/libadf/ADF_internals.o Make/linux64GccDPInt32Opt/libccmio/ccmio.o Make/linux64GccDPInt32Opt/libccmio/ccmiocore.o Make/linux64GccDPInt32Opt/libccmio/ccmioprivate.o Make/linux64GccDPInt32Opt/libccmio/ccmioutility.o Make/linux64GccDPInt32Opt/libccmio/ccmioversion.o
ranlib /opt/openfoam/v1706/OpenFOAM-v1706/platforms/linux64GccDPInt32Opt/lib/libccmio.a
'libccmio/ccmio.h' -> '/opt/openfoam/v1706/ThirdParty-v1706/platforms/linux64Gcc/libccmio-2.6.1/include/libccmio/ccmio.h'
'libccmio/ccmiocore.h' -> '/opt/openfoam/v1706/ThirdParty-v1706/platforms/linux64Gcc/libccmio-2.6.1/include/libccmio/ccmiocore.h'
'libccmio/ccmioprivate.h' -> '/opt/openfoam/v1706/ThirdParty-v1706/platforms/linux64Gcc/libccmio-2.6.1/include/libccmio/ccmioprivate.h'
'libccmio/ccmiotypes.h' -> '/opt/openfoam/v1706/ThirdParty-v1706/platforms/linux64Gcc/libccmio-2.6.1/include/libccmio/ccmiotypes.h'
'libccmio/ccmioutility.h' -> '/opt/openfoam/v1706/ThirdParty-v1706/platforms/linux64Gcc/libccmio-2.6.1/include/libccmio/ccmioutility.h'
'libccmio/ccmioverifymesh.h' -> '/opt/openfoam/v1706/ThirdParty-v1706/platforms/linux64Gcc/libccmio-2.6.1/include/libccmio/ccmioverifymesh.h'
'libccmio/ccmioversion.h' -> '/opt/openfoam/v1706/ThirdParty-v1706/platforms/linux64Gcc/libccmio-2.6.1/include/libccmio/ccmioversion.h'
root@andrea-desktop:/opt/openfoam/v1706/ThirdParty-v1706# ./makeCCMIO lib
after the second command in OpenFoam-V1806:
wmake libso (conversion)
==> skip optional libccm adapter
