[Other] Internal zero thickness walls
Old   October 31, 2012, 10:40
Default Internal zero thickness walls
Chris L
vbchris is on a distinguished road
Hello all,
Would anyone know of a good tutorial or thread that addresses the following issue?
So far I have found these but the solution is not clear to me:
http://www.cfd-online.com/Forums/ope...tml#post332307
http://www.cfd-online.com/Forums/ope...blockmesh.html
http://www.cfd-online.com/Forums/ope...nal-faces.html
My mesh is generated by blockMesh, however when I try to define an internal face as a wall or patch in blockMeshDict I get the error:
--> FOAM FATAL ERROR:
Trying to specify a boundary face 4(151 153 15 13) on the face on cell 76 which is either an internal face or already belongs to some other patch. This is face 0 of patch 3 named internalWalls.
I would like to create a 0 thickness wall. This face is between two meshed blocks. The 4 vertices that make up the face (151 153 15 13) are used to define both blocks and are not duplicated. Is there a general method for defining 0 thickness internal walls?
I am working with OpenFoam 2.1.1
Thanks for your advice.
UPDATE:
Solved by duplicating existing points on internal face and incorporating into hex blocks.
Runs stable.
vbchris is offline   Reply With Quote
Old   May 16, 2013, 10:00
sandy
sandy13 is on a distinguished road
Originally Posted by vbchris View Post
Hello all,
UPDATE:
Runs stable.
Dear vbchris,
I saw your post because I have the same error, did you find the solution? because I am desperate for any hint about this issue. Please let me know If you found it.. Sandy
sandy13 is offline   Reply With Quote
Old   December 9, 2020, 07:34
Fortunato Neto
Forbraer is on a distinguished road
Hello guys.
Even seven years later, there's a man with the same problem here.
If someone could help. I truly thanks.
Santos Dumont - Father of Aviation
Forbraer is offline   Reply With Quote
[Other] Internal Walls in mesh Rakkiran OpenFOAM Meshing & Mesh Conversion 6 April 15, 2021 02:48
[blockMesh] Problems with "holes" or "gaps" in Baffle as internal wall of zero thickness RuKa OpenFOAM Meshing & Mesh Conversion 0 January 11, 2014 09:40
[Commercial meshers] How to get rid of internal walls (surfaces)? bmikuz OpenFOAM Meshing & Mesh Conversion 17 December 5, 2013 15:24
[Other] How to define internal walls for injector inside a combustion chamber by OF2.1.1 with sandy13 OpenFOAM Meshing & Mesh Conversion 0 May 22, 2013 06:59
[Other] How to create zero thickness internal walls in a given mesh in OpenFOAM? karkar OpenFOAM Meshing & Mesh Conversion 1 July 9, 2012 04:13
