December 3, 2020, 23:57 |
importing from fluent to foam
CH VINOD KUMAR REDDY
Rep Power: 5 |
Hi friends,
I created a geometry in fluent and a mesh file in .msh and ASCII format. Then tried to import into openfoam by using fluentMeshToFoam command. I got the following error chitti@LAPTOP-PE3G8S0K:~/OpenFOAM_files/sim3c$ fluentMeshToFoam chitti.msh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2006 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _b45f8f6f58-20200629 OPENFOAM=2006 Arch : "LSB;label=32;scalar=64" Exec : fluentMeshToFoam chitti.msh Date : Dec 04 2020 Time : 10:15:59 Host : LAPTOP-PE3G8S0K PID : 426 I/O : uncollated Case : /home/chitti/OpenFOAM_files/sim3c nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM FATAL ERROR: fluentMeshToFoam: file "chitti.msh" not found From int main(int, char**) in file fluentMeshToFoam.L at line 921. FOAM exiting Can u help me in finding my mistake please |
December 4, 2020, 02:07 |
Rep Power: 8 |
Is the file "chitti.msh" in the directory "/home/chitti/OpenFOAM_files/sim3c"?
December 4, 2020, 02:12 |
Rep Power: 5 |
December 12, 2020, 03:04 |
Farzad Faraji
Rep Power: 7 |
Is it 3D or 2D?
Farzad |
[snappyHexMesh] snappyHexMesh error "Cannot determine normal vector from patches." | lethu | OpenFOAM Meshing & Mesh Conversion | 1 | June 3, 2020 07:49 |
[mesh manipulation] refineMesh Error | mohsen.boojari | OpenFOAM Meshing & Mesh Conversion | 3 | March 1, 2018 22:07 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
