[blockMesh] issues with curvatures faces on blockMeshDict (Hydraulic Fracturing Geometry) |
January 18, 2021, 00:58 |
Axel Dorian
Rep Power: 7 |
Hello all,
I am a student relatively new to Openfoam. I am building a pre-existing fracture geometry (as in the figure in attached) and I am facing issues on the inlet faces which are curves faces. Here below is the error: --> FOAM FATAL ERROR: Trying to specify a boundary face 4(11 26 25 10) on the face on cell 1 which is either an internal face or already belongs to some other patch. This is face 0 of patch 0 named inlet. From function polyMesh::setTopology ( const cellShapeList& cellsAsShapes, const faceListList& boundaryFaces, const wordList& boundaryPatchNames, labelList& patchSizes, labelList& patchStarts, label& defaultPatchStart, label& nFaces, cellList& cells ) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 357. FOAM aborting Aborted (core dumped) The blockMeshDict File is also in attached. Please help me out with issue. I have trying to solve the problem without any solution. Best Regards, Axel |
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 09:23 |
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' | BrendaEM | OpenFOAM Meshing & Mesh Conversion | 12 | April 3, 2022 18:32 |
[snappyHexMesh] Help with Snappy: no layers growing | GianF | OpenFOAM Meshing & Mesh Conversion | 2 | September 23, 2020 08:26 |
decomposePar -allRegions | stru | OpenFOAM Pre-Processing | 2 | August 25, 2015 03:58 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 14:49 |
