[snappyHexMesh] Why castellatedMesh phase distort the far field mesh.
Old   January 19, 2021, 23:40
Default Why castellatedMesh phase distort the far field mesh.
ozi
Ph.D.(c) Oğuzhan KIRIKBAŞ
ozi is on a distinguished road
Hello;
After a long break I am currently trying to return OpenFOAM with the goal of simulating the flow around DARPA Suboff configurations for maneuvering analysis. In my current case I want to do a drag calculation of AFF-1 (only barehull) configuration. I made a background mesh with blockMesh which uses a multi region grading in order to get a relatively fine mesh around the geometry. Then I only use the "castellatedMesh" part of the snappyHexMesh. This refined the mesh in the vicinity of the object but also tried to refine far field mesh arbitrarily as you may see in the ss (2D slice) attached. Can you give me an advice for this problem and also improving the quality of my mesh. Attachment 82203
Attachment 82204
Attachment 82205
ozi is offline   Reply With Quote
castellated mesh, snappyhexmesh
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
foam-extend-4.1 release hjasak OpenFOAM Announcements from Other Sources 19 July 16, 2021 05:02
[snappyHexMesh] High quality mesh for wind in complex urban environment ziboaa OpenFOAM Meshing & Mesh Conversion 1 January 12, 2021 15:33
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
