[snappyHexMesh] setFields does not work after running snappyHexMesh parallely
Prev Previous Post   Next Post Next
Old   March 1, 2021, 16:10
Unhappy setFields does not work after running snappyHexMesh parallely
Deutschland
vava10 is on a distinguished road
Hey everyone,
my work flow is as follows
1. surfaceFeatureExtract
2. blockMesh
3. topoSet1
4. refineMesh
5. topoSet2
6. refineMesh
7. topoSet3
8.  refineMesh
9. decomposePar
10. mpirun -np 4 snappyHexMesh -parallel
11. reconstructParMesh
12. setFields
this workflow did not give me any error in the terminal
after this when I try to view the setField results I was unable to visualize the result. I have been trying to resolve this for a week. recently I tried to run the snappyHexMesh without using parallel (just using 1 processor). Then I tried to visualize the result and I was able to visulaize it.
I tried parallel running using the info got from this link : https://www.openfoam.com/releases/op...+/parallel.php
it also did not help
openFoam version - v2012
from all this I came to conclusion there is something wrong with the parallel running portion of the work flow.
So I tried few of the suggestion from different error posted in the form regarding parallel run. But still I was unable to fix it
CAn some one PLEASE help me
if you need further information regarding the case set up please feel free to ask
Kind regards
vava10
vava10 is offline   Reply With Quote
[snappyHexMesh] reconstructPar after running snappyhexmesh in parallel fidu OpenFOAM Meshing & Mesh Conversion 11 October 20, 2020 09:01
[solids4Foam] HronTurekFsi3 Laminar Tutorial not running parallel using Foam-Extend 4.1? EternalSeekerX OpenFOAM CC Toolkits for Fluid-Structure Interaction 0 May 29, 2020 03:12
Error while running chtMultiRegionFoam parallely Sanoja OpenFOAM Running, Solving & CFD 2 July 10, 2015 06:22
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
[snappyHexMesh] SnappyHexMesh not generate mesh first time mavimo OpenFOAM Meshing & Mesh Conversion 4 August 26, 2008 07:08
