[Gmsh] How to create one solid per surface when exporting STL files?
Like Tree4Likes
  • 1 Post By Reptider
  • 3 Post By saladbowl
Old   March 22, 2021, 07:59
Default How to create one solid per surface when exporting STL files?
Reptider is on a distinguished road
Hello!
I create physical surfaces for using them in OpenFOAM later in .geo thanks to:
Merge "fisrt.stl";
Surface Loop(1) = {1};  // first surface*
Physical Surface("firstWall") = {1};
Merge "second.stl";
Surface Loop(2) = {2};  // second surface*
Physical Surface("secondWall") = {2};
Volume(1) = {1,2};
Physical Volume("Volume") = {1};
I can create a stl file using Export -> ASCII + per physical surfaces and receive nessecary results in stl file like:
solid firstWall
endsolid firstWall
solid secondWall
endsolid secondWall
However, when I use in the terminal this command: "gmsh -2 name.geo -o name.stl:, I get a single solid:
solid Created by Gmsh
endsolid Created by Gmsh
How can I do this operation using only the terminal?
Thanks!
saladbowl likes this.
Reptider is offline   Reply With Quote
Old   May 17, 2021, 20:44
Juan Salazar
saladbowl is on a distinguished road
I figured a way to do this by changing some default options in gmsh. I am using version 4.8.1. Open the GUI, then
Help --> Current Options and Workspace
Then search for the option Mesh.StlOneSolidPerSurface and set it to 2;
Mesh.StlOneSolidPerSurface = 2;
Click Update (lower right corner)
Before closing gmsh, go to Menu "Tools", select "Options", select "Advanced Tab" and check the option "Save options on exit".
Now when meshing and exporting from the command line you should get the desired behaviour.
keitaro7_14, Reptider and qwertyus like this.
saladbowl is offline   Reply With Quote
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[snappyHexMesh] Add additional boundary layers to complex stl surface tobijingles OpenFOAM Meshing & Mesh Conversion 1 October 26, 2011 10:45
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
solid edge problem....can you help? cindy Main CFD Forum 3 April 5, 2004 13:43
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
