[mesh manipulation] TopoSet error in NearestToPoint |
April 19, 2021, 00:42 |
#1 | ||
Sunag R A
Rep Power: 6 |
Dear All,
I am trying to create a pointSet from a list of points provided from external file in TopoSet. The assignment is as follows. Quote:
After running topoSet, this assignment does work and create a file pointsPatch1 in constant/polymesh/sets as expected. But it throws an error as below. Quote:
Where do I put the keyword "name" in the assignment.? What am I missing here? Any leads will be appreciated. Regards, Sunag R A. |
keyword, mesh manipulation, openfoam, points, toposet |
[Other] Error: topoSet – create patch from .stl – searchableSurfaceToFaceZone | carl_r | OpenFOAM Meshing & Mesh Conversion | 1 | November 18, 2022 17:06 |
fail to run series of runApplication topoSet -dict | jiahui_93 | OpenFOAM Programming & Development | 1 | May 25, 2022 12:56 |
bug : topoSet STOP RESPONDING while trying to make cellzones near to a surface. | sk11 | OpenFOAM Bugs | 0 | March 1, 2021 11:49 |
[snappyHexMesh] TopoSet does not select all faces | Mondal131211 | OpenFOAM Meshing & Mesh Conversion | 3 | July 24, 2019 09:39 |
[snappyHexMesh] Porous Media using TopoSet | RobertoCirolini | OpenFOAM Meshing & Mesh Conversion | 3 | August 30, 2016 08:34 |
