[blockMesh] Blockmesh for a wedge shaped geometry used for simulating flow in pipe(hp eqn) |
May 10, 2021, 02:52 |
New to OpenFOAM
Please let me know why I'm getting this error --> FOAM FATAL IO ERROR: "ill defined primitiveEntry starting at keyword 'blocks' on line 30 and ending at line 92" file: /home/cfdpopeye/OpenFOAM/cfdpopeye-8/run/cavity_week_eleven/system/blockMeshDict at line 92. From function void Foam::primitiveEntry::readEntry(const Foam::dictionary&, Foam::Istream&) in file db/dictionary/primitiveEntry/primitiveEntryIO.C at line 168. FOAM exiting /*--------------------------------*- C++ -*----------------------------------* ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0.000000 0.000000 0.000000) (0.000000 -0.000262 0.009997) (0.000000 0.000262 0.009997) (3.520000 0.000000 0.000000) (3.520000 -0.000262 0.009997) (3.520000 0.000262 0.009997) ); blocks ( //hex(0 3 5 2 0 4 1 0) (20 1 20) simpleGrading (1 1 1) hex(1 4 5 2 0 3 3 0) (1 20 20) simpleGrading (1 1 1) ); edges ( arc 1 2 (0 2.617695e-04 9.996573e-03) arc 4 5 (3.520000e+00 2.617695e-04 9.996573e-03) ); boundary ( inlet { type patch; faces ( (0 1 2 0) ); } outlet { type patch; faces ( (3 5 4 3) ); } frontandback { type wedge; faces ( (0 3 4 1) (0 2 5 3) ); } axis { type empty; faces ( (0 3 3 0) ); } top { type wall; faces ( (1 4 5 2) ); } ); mergePatchPairs ( ); // ************************************************** *********************** // below i have attached the image which could help u visualize the geometry diag.png |
Flow modeling in 2D geometry as helical coil | Ash Kot | OpenFOAM | 0 | January 6, 2021 19:28 |
Wedge Shaped Hopper | Arun | FLUENT | 0 | December 31, 2007 06:27 |
Is an uniform flow possible for this geometry? | Michael Hu | FLUENT | 1 | April 13, 2006 22:11 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
